-   -   TRS Gear Housing (https://www.offshoreonly.com/forums/general-q/87053-trs-gear-housing.html)
38KV 09-15-2004 01:55 PM
TRS Gear Housing
Broke a skeg last weekend. Broke it so bad I can't weld it. :(
Looking for a used empty TRS gear housing in good shape.
Does anyone know if the RH and LH rotation
TRS use the same lower gear housing or not?
Biggus 09-15-2004 01:57 PM
Re: TRS Gear Housing
Yes, the left and right share the same housing.
Give Mark at BAM a call. He will have a new one.
Kurt
tomtbone1993 09-15-2004 02:02 PM
Dave ATB engine has used ones 936-344-7200
38KV 09-15-2004 02:07 PM
Thanks!
Biggus 09-15-2004 02:23 PM
If you find a used one make sure it has never been repaired from a blown gear. They tend to "stretch" and you will never get a correct gear pattern.
38KV 09-15-2004 03:21 PM
Thanks for the info Biggus. I want to find a used one because I'm considering
Konrads in a near future and don't want to spend that much $$$ on the TRS drives.
Biggus 09-15-2004 03:28 PM
Good move.
I've logged just over 100 trouble free hours on my Konrads. They are rugged as hell. I can't break 'em.
Kurt.
38KV 09-15-2004 03:54 PM
Kurt, do you mind if I pm you if I have some questions
regarding the Konrads later on?
Jonas
Biggus 09-15-2004 03:59 PM
No problem.
Lofty 09-16-2004 07:22 PM
Jonas,
I've got a couple of lower cases you can have if you're interested. PM me with you shipping info.
Fionn
38KV 09-16-2004 07:48 PM
Thanks Fionn! I'll PM you tomorrow. I have to sleep now, time is 2.50 am over here.
