Resleeve Merc Pro Max outboard
Does anyone know a good source for resleeving HP outboard motors in the Detroit or Michigan area?
Re: Resleeve Merc Pro Max outboard
go to www.screamandfly.com for the most info on outboards, great forums!!
We got a local guy around here. You probably do, too, if you ask around at the motorcycle shops.
If you sleeve to cast iron, you gotta run different rings. |
guys that really know what they are doing can still sleeve the original nickle plated cylinders. I think that they hone it differently then a cast sleeve. From what I hear you loose HP with the cast sleeves.
Jon |
If you run an old Bridgeport block, the iron liners are actually necessary if you run nitrous. Otherwise the bridge melts out.
I've had blocks with two iron sleeves, and 4 Nikasil holes. They run just fine that way. Whole lot cheaper than a new block. Course if you just got some light scratches, you can overbore and re-Nikasil pretty affordably. |
| All times are GMT -5. The time now is 06:08 PM. |
