-   -   Stroke, Blower, or Whipple (https://www.offshoreonly.com/forums/general-q/87354-stroke-blower-whipple.html)
mikes280 10-03-2004 07:10 PM
Re: Stroke, Blower, or Whipple
swede have not heard from you we are trying to work out going to keywest hope your motors are working out
Comanche3Six 10-03-2004 07:57 PM
A hydraulic roller cam designed for the supercharged marine engine is a nice way to go. You can have the combustion chambers on the heads opened up to 130 cc and get that compression down. Use a good head gasket like the one from FelPro with the wire in the fire ring to seal those combustion chambers tight. I like to gap my top ring at .026 for that bore size so the ends don't butt from the heat. Ample fuel is a must, lines from the tank to the carb must be sized accordingly or a lean condition will occur. Get it right and you will be happy with the modifications.
Good Luck
Ed
Swede 10-06-2004 06:58 AM
What hydraulic roller cam would you guys recommend for the 509?
vtec 10-07-2004 11:55 AM
572CI or 540CI gm block w/ supercharger.
