bravo to arneson surface conv. >
Old 09-28-2004 | 03:31 PM
HeavyChevSS
Default Re: bravo to arneson surface conv.
Does anyone know what kind of performance increase would be seen in converting from the Bravo to The surface drive setups. Local guy here had a 42' Fountain with Triples and the Surface drives. Don't know what it had for power other than it sounded wicked and have only seen him idling around the beach. Just curious if they are any faster?
Old 10-01-2004 | 12:02 PM
Jim With The Arneson You Will More Than Likely Have To Fill In The Notch In The Transom.and So Real Time To Dial In?sell All Your Bravo Stuff And Go For It.
z.zuperboat is offline
Old 10-11-2004 | 04:40 PM
tjthor
Originally Posted by jcap
Arneson has a bravo to surface conversion including trans and box so no relocating engine .Anybody have any experience? Price? I am in that 700 hp range that doesnt warrent a # 6 but tired of eating Bravos.
First time on here.
I did a custom install of the Arneson conversion kits to a brand new Eliminator Daytona 30. This boat was brand new, never rigged.
The mounts were a bit of work but the end result is absolutely a work of art both cosmetically and in performance.
Handling, speed and general driveability were terrific. This boat ran a pair of 9:1 comp. naturally aspirated 555's with approx. 775hp at 6800 rpm.
We were still experimenting with props but saw an easy 119 mph at less than full throttle.( by approx 600rpm)
Our season is over for now but I will bring more data to the board here next spring.
Overall, I am very impressed with the Arneson drive setup and releived that I will no longer be replacing broken bravo drives. Not only is it expensive when they break but a major let down when you are on holidays with no boat to play with.
Any specific questions, please reply and I will offer what help or info. I can
The support from Rik and Arneson is top notch and they take a personal interest when you have some quetions or problems to be solved.
I cant wait until spring, Whipple 3.3's may be next on the plan!
Ted
Old 10-11-2004 | 09:50 PM
articfriends's Avatar
Ted,wheres the pics??Smitty
articfriends is offline
Old 10-11-2004 | 10:42 PM
tjthor
Hey Smitty
My mechanic/rigger friend is working away from town for a while. He has volumes of step by step install pics. I have a few of the transom and Tie bar setup which I am sending to Rik tomorrow. He will be able to post them I think. My pics are not e picks but are 35mm and I cant scan and post.
Soon,
Ted
Old 10-12-2004 | 02:47 PM
RIK, Does the $16-16,500 include props? and do you run w/wo boxes, (382 Fastech)
What are HP limitations?
thanks,
KL
CAFormula1 is offline
Old 10-12-2004 | 02:55 PM
Ca Formula, I did the conversion on the 382 that was in powerboat mag. Call me if you have any questions about the conversion. Where are you located? Come by and we'll take you for a ride! 925-516-7678. Thanks, Steve Seaton
OffDuty is offline
Old 10-12-2004 | 05:39 PM
Rik's Avatar
Rik
arneson-industries.com
Offshoreonly Advertiser
Unfortunately, the price of the drives does not include propellers. You can ask "Offduty" about the performance and such as he has first had experience with the same boat as yours.
What size power do you want to upgrade to?
Rik is offline
Old 10-13-2004 | 10:57 AM
running GT 1100's (quad whipple) B-Max drives w/Imco lower shafts...obvious week link here is lower units...I just bought the boat..motors and drives are near new...I have put 7 hrs approx 15 hrs total? I have been told to change lower unit bearings at 50 hrs. (providing they live that long) for now I plan to take it easy??
they onlt make 1100 if you push the sticks all the way forward
but being realistic I will most likly have to change the set up in the future.
I would like to some day hook up and check out the Arneson's
We are located in Long Beach area
Old 10-13-2004 | 11:15 AM
jcap's Avatar
I am going to make this a winter project , converting 30y2k superboat (single engine 30 ft narrow beam P4 race boat) from bravo to arneson . I will post my progress. So far Rik from arneson has been great help ( even though I bought used equipment from someone else!)
I have a fresh bravo xr (no hours on an MRD rebuild including gimble rebuild)and complete transom set up for sale! anybody interested? send a pm
Jim Capie JESSIE JAMES P4-30
jcap is offline
