241 Liberator Help?
I Just Bought A Very Nice 1989 241 Liberator My ? Is About Speed And Prop I Know This Is Not A Fast Boat But It Rides The Rough Water Very Nice I've Rode In 30 Footers That Don't Ride That Nice Anyhow Can Someone Tell Me What Prop Came Standard On This Boat With 454 Bravo 1 And What Speed It Should Run It Is A Heavy Boat Thanks
Re: 241 Liberator Help?
Sorry..cant help..But, I had an 86 Lib with twinn 350s...Yes they are VERY heavy!....Good luck !.......Do a search on Liberators....We had some threads way back..."MILORD"....."MISDEMENOR"...I think Have/had Libs
More that likely a 21" Mirage. I had a 1988 21' with a 460 Ford and OMC King Cobra. That had a 21" BUT was a smaller boat BUT also had 1.43 gears not 1.5 like Bravos. It should work out about the same.
I don`t know if this helps but I have a Formula 242 w/454 with a 1.5 gear ratio and I run a bravo 1 22 pitch labbed slightly and runs very nice. The boats I think are close in weight. Hope this helps.
A friend of mine had one of the above mentioned boats,,,with a 21 mirage prop the boat woult run about 53 or so on a good day,,,,God what a tank though,,rode the same no matter what the water was like.
you can go on the fourwinns web site with a vin number and they can tell you what the boat came with.
Go to the Fourwinns website, and go to the archives. Select your year and model, and click on the "fast facts" (I think that's what it's called). There you will find engine sizes, drive ratios, max engine RPM,top speed etc.
Paul |
email me with your contact info, I'd like to talk to you about your boat.(I have an 89 241 with t/350's) [email protected] |
| All times are GMT -5. The time now is 08:51 PM. |
