Re: What causes fuel pressure to rise to the point of needing a regulator?
Don't think I've ever seen the Alpha SS drive - if I did it was too long ago. Got any pictures handy?? It's gotta be alot more effcient than the trs/trans setups the bigblocks used.... A 454 with 425hp with a trs would turn a 25" mirage to 5,000rpm or so, and a 27" to 4,700.
The X-dimension on two different years was also different from the factory on these two boats. The '79 was 1+" deeper than the '82.... |
1 Attachment(s)
here is the alpha ss
Looks like they just "nose coned" it. I presume it's all one casting. Is the water pickup any different than a standard alpha? Boat must run a good bit different than the 454/TRS setups!! They have so much weight on that narrow transom, that when you slow down to come off a plane, you have to be careful not to let the wave crash over the transom!! --the wave will come right on in over the rear seat if you just kill the throttle - pain in the ass. Your boat must be 300lbs+ lighter back there.
I've always heard the alpha's do OK as long as you don't "stroke" or "boost" that small block - "more hp is OK, just don't add lotsa torque".......Enjoy |
| All times are GMT -5. The time now is 07:59 AM. |
