Drive Showers
Who Makes The Best Drive Shower And Were Do You Get Them?
Re: Drive Showers
Imco makes good showers, got two on the victory and no probs, easy install.
Cost about 125 ea look at: http://www.imcomarine.com/pages/on-line.asp |
Re: Drive Showers
Thanks,just Ordered Them!
Re: Drive Showers
I was about to make one.
Then I checked the temp of my A1. It was cold. I think the OD gets hot when it has misaligned gears. Then better fix it, than try to cool. |
Re: Drive Showers
http://www.innovativemarine.net/
http://www.innovativemarine.net/Blktubecooler.jpeg Are the best! Best looking best cooling best fit best design and looks stock unless you want the intercooled units someone else makes the imco is a transom washer :( does NOTHING for the sides of your drive :( Now Billet Marine has a nice unit! http://www.billetmarine.com/Our%20Products.htm http://www.billetmarine.com/our_prod...topcap_set.gif I have never seen one personally, but they look similar to the Innovative design and goes a step farther and has INTERNAL cooling passages. And a claimed stronger top cap. You actually replace your merc top cap with their unit. The Innovative unit does ON top of your stock unit. |
Re: Drive Showers
Another good drive shower that has proven itself over the years is the multiport Simrek "halo" drive shower. It does a pretty good job of cooling a drive as well. A few years ago the Simrek was given a "real world" test by Jim Wilks within the technical column in Hot Boat Magazine and with the new pick-ups it provided something like a 50*to 60* or so in heat reduction of the drive as compared to not using a drive shower at all.
Go to: www.driveshowers.com |
Re: Drive Showers
Innovative Marine Is A Great Unit Also :d
Re: Drive Showers
Re: Drive Showers
Simrek
Re: Drive Showers
Simrek showers work great easy to install, I like the way it showers both sides and the top, Not just the top like the others. At the end of the boating season your drive is not discolored.
| All times are GMT -5. The time now is 05:07 PM. |
