-   -   Low engine temp (130)when running boat in water (https://www.offshoreonly.com/forums/general-q/89201-low-engine-temp-130-when-running-boat-water.html)
JGB 10-23-2004 12:16 PM
and normal engine temp (180) when running on the hose. Any ideas what could be going on?
hotlavey 10-23-2004 01:42 PM
Re: Low engine temp (130)when running boat in water
I would guess that you're not getting as much water through the hose as you are when in the water.
JGB 10-23-2004 02:39 PM
Well I guess if that's the case, why wouldn't I be able to bring the engine up to temp at 180 while running in the water? Thx
Ted G 10-23-2004 02:57 PM
130 is not a problem unless your oil temps are too low. If you are getting condensation you may need to add an oil thermostat to bring it up some. Oil should be around 210 on a run.
Hang Time 27 10-23-2004 03:06 PM
How about the best location for oil temp sender for those temp #'s? In the pan or the block?? Has anyone tried the different locations on the same boat for commparative results?? Ones guys 210 might be the same as another guys 240.??.......
Hang Time 27 10-23-2004 03:09 PM
PS. JGB - those are the same kind of #'s I've always seen. I run a 140 degree thermostat with bypass hose. I guess when the boats in the water the supply is just that much better. I would think a water pressure gauge would answer that question.
JGB 10-23-2004 03:18 PM
Thanks guys I guess I better just move to doing a compression. check. BTW, IS a max of 4500 rpm normal for an '85 merc 260?
Ted G 10-23-2004 03:24 PM
I've seen them in the pan and in the oil filter housing. Oil temp between 200 and 280 is fine so a 10 or 20 degree difference at different points on the engine is insignificant. I have been told that up to 320 is okay for short times also but it is a little freaky seeing it up there.
