-   -   Completed the compression test on my '85 merc 260 (https://www.offshoreonly.com/forums/general-q/89264-completed-compression-test-my-85-merc-260-a.html)
JGB 10-25-2004 09:14 PM
Re: Completed the compression test on my '85 merc 260
So would that mean I am looking at a rebuild if that's what the leak down test showed? thx
Jim
articfriends 10-25-2004 11:17 PM
Proof is in the leakdown test,i did my motor a few wks ago and my weakest cyl had 120 psi crank compression (after 10 cycles),80% leakdown!!!,best cyl had 10 % leakdown and was bumping 160 psi after 4 cycles of motor. Funny thing was boat ran ok,was 1/2 mph off normal speed and didn't have much blowby. When you did your compressioin test did the lower press cylinders take more turns/cycles of the motor to get to there max? If they did it is definately weak,leakdown test,post your results,Smitty
Michael1 10-26-2004 01:04 AM
Originally Posted by JGB
was told engine had 40 hours on a rebuild. certainly can't belive that.
Jim
Or they rebuilt it, and got the ring gaps too wide. This pearl of wisdom comes from the blowby encountered after a friend rebuilt his engine back in high school. That car was liking driving around a oil geyser!
Michael
JGB 10-26-2004 08:57 AM
the blow by seen is a alot. there are 2 mr gasket breathers on the valve covers(one on each side. When I slow down to idle after a run and open the engine hatch it looks like a smokehouse.
Carb was rebuilt twice because after the first rebuilt it started flooding the engine after 10 min of run time.
The motor has a mild aftermarket cam which I thought it should be running higher than 4500 rpm.
