-   -   Range of pitch for SSM props (https://www.offshoreonly.com/forums/general-q/89353-range-pitch-ssm-props.html)
Gary Anderson 10-26-2004 01:50 PM
Anyone know the range of pitch (lowest & highest) for SSM props? Both small (II, III, early IV) and large shaft (IV, V, VI).
Gary
waterbum 10-26-2004 04:11 PM
Re: Range of pitch for SSM props
When I was looking for props for my older SSM 3, I found pitches ranged from 26 to 30. Diameters ranged from 16 to 18. Found a set of 16s cut down to 15 1/2. Only found 3 blade props.
Also discovered that there is a hub insert (spacer) you can put on small shafts and use #6 props. Opens up a lot more possibilities.
Doug
