-   -   Raw Water pump Impeller wear? (https://www.offshoreonly.com/forums/general-q/89646-raw-water-pump-impeller-wear.html)
blue thunder 11-01-2004 06:39 PM
Re: Raw Water pump Impeller wear?
Aside from what the others have said, I find it helpful to prefill the intake hose with water to the pump before starting. This primes the pump and gets the requisite coolant flowing (water) to take heat away from the impeller blades. If you don't do this it can take many seconds to suck water up and prime the pump particularly if the suction side is not 100% air tight. This takes mucho life off the impeller.
BT :cool:
CAP071 11-02-2004 07:22 PM
I found myself still replacing my Globe impeller every season just for the satisfaction of it being new and not an old one in there. Although I have to say It looked GREAT when replacing :eek: But I just wanted cheap insurance out on the water. But that doesn't prevent picking up crap on any given day in dirty water
RLW 11-02-2004 07:38 PM
2 Attachment(s)
Here are two pics of a 25 hour Globe Blue.
mikes280 11-02-2004 09:10 PM
i need a key for the blue impellers help
CAP071 11-02-2004 09:12 PM
Trenton Marine in Nj stocks them
mikes280 11-02-2004 09:14 PM
thank you
CAP071 11-02-2004 09:17 PM
http://trentonmarine.com/parts.htm
