Cam Help
Hi, I Have 572ci Engines With Pocket Ported Dart 308 Iron Eagle Heads, Dart Intake, 1050 Cfm Dom And Comp Ratio Is 9.5:1. I Need Help Choosing Hyd Roller Cams. Can U Guys Give Me Your Input Please. Thanks. P.s. I Am Willing To Turn Them 6000 Rpm. 700+ Hp Is What I Will Like To Achieve.
Re: Cam Help
I am sure that I can get Rmbuilder to lend some assistance. It will require a visit and on water evaluation to your location.
:drink: |
Re: Cam Help
cigarette39,
Do you have flow #'s for the heads you are using? We can give you some cam help but need to know the specifics. 700+ is very obtainable, what is the peak RPM you want to run this? Bob |
Re: Cam Help
I will like the peak RPM to be around 6000. I will get the flow # for you on Monday. Thanks.
| All times are GMT -5. The time now is 11:37 AM. |
