-   -   Alpha 1 mystery Leak. (https://www.offshoreonly.com/forums/general-q/90131-alpha-1-mystery-leak.html)
seapotato 11-08-2004 11:02 PM
Alpha 1 was pressure tested at 6 psi for 48 hours.
No pressure drop whatsoever.
Boat launched in salt water.
After 1 day in the water boat pulled out - the gear oil was clear.
After 1 month in the water the gear oil was milky.
The milky oil was drained. Pressure tested again - 6 psi for 48 hours - holds pressure OK.
Could anyone guess what may be wrong?
Thank you.
Biggus 11-09-2004 12:23 AM
Re: Alpha 1 mystery Leak.
Pressure test means nothing. You need to do a vacuum test. We see it all the time, a drive will hold pressure but not the vacuum test. (pressure aginst the seal will cause it to seal itself)
If there are no visible leaks, it probably is a shift shaft seal.
Kurt.
mopower 11-09-2004 03:39 PM
I had a 2002 Bravo out of the box that oil would disappear from :confused: . Sit in the driveway all week and it was fine. After checking everything possible I was able to take a quarter turn on all the bolts between the upper and lower gearcase. Never did SEE a leak but this stopped it :cool: .
jpclear 11-09-2004 07:03 PM
Like Biggus said; you have to do both the pressure AND vacuum test. And I would like to see them hold 10-12 #, not just 6. That being said; if there is no fish-line around the prop-shaft, it's the shift shaft seal 90% of the time. --- JP
