-   -   exhaust systems (https://www.offshoreonly.com/forums/general-q/90231-exhaust-systems.html)
smuggler 24 11-10-2004 02:35 PM
exhaust systems
I am running a small block with 450 hp. I have to buy new exhaust manifolds. Imco´s powerflow series locking good for my engine. Is there any one how has experience for those or can recommend adders ?
Which duration on the cam are coursing water problems?
ONESICKGLADIATOR 11-10-2004 06:45 PM
Re: exhaust systems
Originally Posted by Too Old
I'd recommend Stainless Marines system. They offer a 5 year warranty and stand behind their product. Excellent exhaust.
well said too old
Escape Velocity 11-10-2004 08:01 PM
Re: exhaust systems
I was happy with Stainless Marine's manifolds and polished stainless risers on my 383 stroker engine. The engine was built by Tyler Crockett and Stainless Marine was his recommendation. If I remember right, the engine was 445 ft/lbs torque, and 400+ horsepower.
smuggler 24 11-11-2004 04:31 PM
Re: exhaust systems
I don´t know if I like Stainless Marine´s manifolds. I have today Marrs manifolds hows look like a headers and is maid of aluminum. They has cracked inside and I am worried about my engine. I think Imco´s manifolds looks nice. Isn´t it anyone how has experience off those manifolds? My engine has a stroke at 383, 420 ft/lbs at 5200 rpm and 450hp at 5600rpm.
SeaRay Jim 11-11-2004 05:51 PM
Re: exhaust systems
What is it about Stainless Marine you don't like? At least what I got form that is that you don't care for them. I honestly have to say, I'm not sure what the rest of the post was saying. :confused:
JCourt 11-11-2004 07:23 PM
Re: exhaust systems
The biggest reason to go with Stainless Marine rather than IMCO is that IMCO uses a through the flange water passage just like the stock manifolds. Stainless uses a jump hose from the manifold to the tailpipe.
Blow a gasket with the IMCO's and kiss you just might suck water into your engine.
pullmytrigger 11-11-2004 10:02 PM
Re: exhaust systems
does Dana make small block manifolds?????
88Fount33 11-12-2004 09:22 AM
Re: exhaust systems
I ran a 406 CI spinning a 15.5 X 27 four blade Hydromotive with solid lifter Ultradyne cam to 80+ (GPS) at 4200 rpm in an 18' Formula using Stainless Marine System. Exhaust never reverted (in two years of operation) idle speed 1000 rpm. Blew a drive, way crazy too much power. Stopped dial in (needed to upgrade fuel delivery system, as leaning out at WOT) as boat was undriveable even with tabs down. Stainless Marine with the warranty is the way to go on a budget.
aero-offshore 11-12-2004 02:29 PM
Re: exhaust systems
2 Attachment(s)
I believe you can get imco's either way, through or bypass, those stainless marines look way better than the powerflows IMO,and with the way Imco has been doing biz lately, TOO OLD's getting ALL of my biz.
