-   -   Engine dyno numbers (https://www.offshoreonly.com/forums/general-q/90237-engine-dyno-numbers.html)
375stinger 11-10-2004 04:11 PM
Engine dyno numbers
Dyno'ed two of three engines so far, one with 606 hp, other with 631hp. The engines were all just rebuilt with all the time in the dyno. Is that much of a difference in numbers pretty common?
Mudball 11-10-2004 07:56 PM
Re: Engine dyno numbers
That's about 1%!!!
Pretty darned good, IMO.
Strip Poker 388 11-11-2004 08:48 AM
I would think your average hp would be more important.
Would 25 hp say at 3500rpm make a difference in throttle position???insynk?
JIMG 11-11-2004 11:20 AM
1% You Might Want To Recheck Your Math
HiPerf2000 11-11-2004 12:04 PM
that's what i was thinking :rolleyes:
more like 4%.
I agree with strip. check avg.
375stinger 11-12-2004 07:09 PM
hawk 511ci bored to 551. 1050 diminators, same carburator was used for all engines. 2rd engines came in around 632hp. If i put the 606hp engine in th center wouldnt it be ok?
375stinger 11-12-2004 07:10 PM
nevermind 3rd engine came in around 632 hp
JCPERF 11-13-2004 07:14 PM
Should be within 5hp. 10 at the most.
mcollinstn 11-13-2004 08:32 PM
Head porting differences (whether they are as-cast or have had port work done) will account for a few hp difference. CNC ported heads, cc'ed chambers, and individually degreed cams will result in very very little hp diff between otherwise identical motors.
30 hp is more than you'd like to see.
Infomaniac 11-13-2004 09:20 PM
Leakdown test the low HP engine? Any other differences?
Oil pressure, water temp, oil temp, BSFC?
