-   -   Compression on BlowerMotor? (https://www.offshoreonly.com/forums/general-q/90366-compression-blowermotor.html)
IRONMAN 11-12-2004 04:54 PM
What is the optimum Compression Ratio for a mild boost Supercharged engine 3-5 psi and 500 - 550 cubic inches. This would be for pleasure use 89 octane and a hyd roller cam at less than 5600 rpm.??
Turbojack 11-12-2004 05:25 PM
Re: Compression on BlowerMotor?
7.5-8. The lower the static compression is the more boost you can add to make more HP. Such as a motor at say 8.5:1 can not stand as much boost before detonation sets in as a 7.5:1 motor.
PROFILE 11-12-2004 05:27 PM
I would'nt run much more than 8.5:1.Also would use only premium 91 octane fuel.
KNOT-RIGHT 11-12-2004 05:43 PM
Im with TurboJack. If your building a blower motor I would run 7.5 to 8.0.
Most Blower kits are based on production motors usually 8.5,9.0-1. The majority of the consumers install blowers on production motors. That exsplains why you will see alot of higher compression motors with I.E. Prochargers , Whippiles, etc.
The lower the static compression the more boost one can run.
Check it out.
http://www.kuhlsuperchargers.com/tech%20p05.htm
cobra marty 11-12-2004 05:49 PM
If you start with too low static compression the motor will be sluggish until up on boost. For 3-5 boost you should be OK and happier with 8.5 with a centrifugal type blower.
Turbojack 11-12-2004 09:26 PM
Depends on blower. I have had them where at 1500 rpm or less when I went wot I had full or close to it boost & was not sluggish at all. The motor I now have has the hightest compression I have ever had on a blower motor & I am at 8:1
Michael1 11-13-2004 01:42 AM
Turbojack,
I sounds like a you did not have a centrifugal blower. The boost out of those are highly dependent on rpm.
Michael
ratman 11-13-2004 02:40 AM
im building 588s with 1071's and in the last three weeks have talked to most of the big blower builders, cobra,tyler crocket, zul, steve burle, the whole combination has to be sized for each other components in that if you have too low a static compression you will need a larger blower or you will have to spin a smaller one too hard to make boost and generate a lot of heat. the better the heads and exhaust flow the more power you can make with less boost as restrictions in the engine increase boost. randy at cobra says exhaust port work alone is worth 75 ponies. i saw the exhaust ports on the brodix heads they run and the exhaust is f**ing huuuge! i was going to go 7 to 1 but they all advised me to run more staic 8.25 to one so my 1071 would work with my 588's and not be lazy at idle from too little compression nor would i have to spin the blower exccessivly hard to make good power under boost. everyone i spoke with also told me to run intercoolers to prevent detonation and make another 75 or so ponies in doing so. so kep in mind heads exhaust, displacement and blower size all must work together. decide waht kinda power you want to make and then pick the components you'll need to make that #. i was down at cobra today and he has a bunch of used blowers that can be bought resonably. i've never seen so many blower motors in one place in my life,they do a ton of em and have blown up enough stuff over the years to know what does and doesn't work. good luck with it ,spend some time talking with these folks they were all kind enough to talk at length about what has worked for them and they have the answers.
ratman 11-13-2004 02:46 AM
by the way while 3 lbs of boost doesn't sound like a lot, scott at intense marine has a pair of 540" 990 iron head 871 blower motors that dynoed @ 825 hp with 3.5 lbs of boost using 2 850 holley 4150 carbs !
ratman 11-13-2004 02:48 AM
cobra jack what size motors and blowers do you run? r u over or under driven? what percent? what kinda hp & torque? thx ratman
Turbojack 11-13-2004 07:04 AM
Originally Posted by Michael1
Turbojack,
Michael
I think since the late 70's I have had just about everthing. Now I have a procharger M4 with 8:1 compression on a 540bbc. I wanted to go 7.5 but was told with my setup the pistons would not work.
Is my low end sluggish? Yes, compared to other setups I have had, but I can still pull 4 llbs of boost off idle & goes to 11.5 @ 5800rpm. If I had gone quad rotor whipple I would have way more boost off idle but I also may be spending more time installing new drives.
As rat said it all depends on what you are trying to acomplish. This thread was stared with a question of what compression to run on regular 89 gas & 3-5lbs of boost. My answer is Max 8:1 You want more low end? Add more cubes. As I stated above you can make more HP before detonation sets in with a lower static compression ratio & more boost then with a higher static & less boost with the same octane gas. I think the 575 supercharged mercuriser engine only runs 7.5:1
IRONMAN 11-13-2004 07:41 AM
Thanks, I am still trying to decide weather to add a blower to a 509 or build a 572 - 598 NA motor. Either setup should yield 725++ Hp and be reliable.
ratman 11-13-2004 07:15 PM
i was originally going to go n/a but several engine builders told me that valve train problems plague hi output n/a motors because you need so much cam lift and duration. blower motors ran a mildrr hydrolic rollers for less valve train maint. if you only want to run 3 or so lbs of boost you may want to talk to scott @ intense maarine i think he told me the stacic comp on his 540's was 8.5 because was was only going to run a 871 blower. he would have run less compressions with a 1071. research yuor project well. goog luck
Infomaniac 11-13-2004 08:19 PM
89 octane is the real issue.
Regardless of what compression is best running on the engine or on the blower.
7.7:1 is doable with a 4" stroke and keep a decent quench clearance. A 4.250 stroke will up the compression a bit to around 8.4 using shelf pistons and 118 CC heads.
I would opt for the 7.7:1 if you are absolutely limited on octane. You can always boost up later.
cooltoys61 11-14-2004 12:50 PM
Don't forget, the cam you choose will have a large impact on your "real compression".
Pismo10 11-14-2004 12:56 PM
Oh no Ironman, you got the bug again eh...............
Infomaniac 11-14-2004 12:57 PM
This is correct.
