Pirelli flooring
I want to replace my pirelli floor in my TG, what is the best way? Heatgun?, also what will remove the old adhesive afterit is up? Want to replace w/ new wave pattern but it only comes 6' wide? how does that work? Thanks.
Re: Pirelli flooring
who has the new wave pattern? i'd try a heat gun to soften adhesive, then try laquer thinner to remove glue as thinner disolves it with a clean rags. you wil need a lot of cleans rags to sop up molten glue. wear some gloves and a resperator or you'll get a nasty buzz from the thinner. keep in mind its as flamable as gasoline.good luck let us know how the heat gun and the thinner work. good luck
Rat,
Thanks, lonseal has it, but it only comes 6' wide and the Topgun's cockpit is like 6' 4". If I use dot pattern then I could just lay it sideways and put seam under back seat. http://www.lonsealspecialty.com/londeckwv.html# |
| All times are GMT -5. The time now is 09:22 AM. |
