-   -   Any one got a set of stock Merc. engine mounts laying around? (https://www.offshoreonly.com/forums/general-q/90527-any-one-got-set-stock-merc-engine-mounts-laying-around.html)
Waterfoul 11-15-2004 07:54 PM
Want to get rid of them? I need a set for a project I'm doing to make moving my motors around a bit easier.
How about a busted up or useless bell housing??
'Foul
WETTE VETTE 11-15-2004 08:20 PM
Re: Any one got a set of stock Merc. engine mounts laying around?
How is the project coming? Will we see the foul at Hardy next season?
Craig
Waterfoul 11-15-2004 08:29 PM
Hopefully! I'm sure it will be running by spring (or earlier). You'll see it at Hardy if I still have it at that time.
So, you got any stock mounts laying around??????? Would give me a reason to drive south for dinner with Vickie
formula31 11-15-2004 09:39 PM
Mike, I have a BBC bellhousing from an 88 that has the small hole for the triangular coupler. Would this work for you? Are you planning on having the coupler installed while moving it around?
Waterfoul 11-15-2004 09:42 PM
Yeah, I want to make a kind of cradle... I've got 2 motors that will at times end up in the back of my truck, and I'd really like to keep them from moving around. But, I need a bell housing and some motor mounts to build it. Can't use the ones on the motor in the boat, because it's... well... holding the motor in the boat!!
Just thought I'd check to see if anyone had some junk laying around they wanted to get rid of.
So, you wanna get rid of your bell housing???
twinzilla 11-15-2004 09:44 PM
Waterfoul,
I came across these the other day (they're not mine).....but the seller says he has three sets. :D
http://cgi.ebay.com/ebaymotors/ws/eB...category=31285
Twin
2112 11-15-2004 10:06 PM
I have a set of front offshore mounts. Steel. need paint only.
Probably want 50 bucks pluse shipping for the pair.
PM if interested.
Cord 11-16-2004 08:08 AM
Mike, GM used to ship their engines in a crate that was built from 2x12's. They were in a box shape with the pan rail sitting on the box. Looked pretty simple to build. I believe the weight would be on the pan bolts, not the rail so the pan shouldn't be distorted.
Waterfoul 11-16-2004 04:43 PM
Tim, I don't want to have to be that exact!! LOL!!
I'll bet JimV has a set laying around... I'll have to give him a call.
Cord 11-17-2004 08:31 AM
Then use a hatchet to cut the boards! Scheeks! :D
