-   -   timing chain and cover (https://www.offshoreonly.com/forums/general-q/90659-timing-chain-cover.html)
boatn70 11-17-2004 06:49 PM
my short block is a new gen6 it has the OEM single row chain.
1. is this setup ok for 470-550 NA hp
2. will a double row chain fit under the cover
3. is a cam made for a double row chain any better (i havent bought the cam yet)
4. is there a reason the single is not OK
5. is the cover reusable, someone said the cover is not reusable.
thanks
kevin
Pat McPherson 11-17-2004 07:14 PM
Re: timing chain and cover
Hey Kevin,
The ZZ502 500HP/502 uses the single roller chain.
I would think a single roller is fine unless you change to a solid lifter cam and real heavy valve springs...
Yes, the cover is reusable...
boatn70 11-17-2004 07:17 PM
Thanks, if anyone else has any input for me let me know.
do i have to order a cam that is compatable with the single roller chain though??
kevin
mcollinstn 11-17-2004 07:35 PM
Cam doesn't care what chain you run.
Only cares whether it is for a MkIV or Gen5,6.
Strip Poker 388 11-18-2004 01:24 AM
Cloyds makes a hex a just for thegen 5-6. around 120.00.
Pat McPherson 11-18-2004 01:14 PM
I ordered and used a Cloyds set when I fixed my engine.
To tell you the truth, I think the Chevy High performance set looks beefier...
I plan to rebuild another GenVI this off season and I will buy the stock roller chain.
