-   -   Aluminum dash gage panel thickness (https://www.offshoreonly.com/forums/general-q/90755-aluminum-dash-gage-panel-thickness.html)
Zanie 11-19-2004 09:56 AM
I'm getting ready to tackle my dash/gage panel.
What thickness aluminum plate has everybody used for their dash/gage panel?
I was most likely going to use 1/8" thick aluminum.
Thanks,
Dan
Reed Jensen 11-19-2004 11:38 AM
Re: Aluminum dash gage panel thickness
Thanks,
Dan
I used 1/4 inch on my Fountain... only because the dash panel supported the steering ... I wanted it beefy...... If it's just holding the gauges.. 1/8 is plenty thick.
BadDog 11-19-2004 03:14 PM
Consider coating the back of the panel with something non conductive. Even sticky plastic shelf paper. You never know what might come loose back there.
Zanie 11-19-2004 03:33 PM
Hey good idea, it will also act as a gasket when mounting the panel to the dash.
Boomer 880 11-19-2004 04:22 PM
How/where do you send it for engraving?
I also need to build a new dash panel, but not sure how to get the panel with the switch names engraved, and I do not want to use stickers or anything too sloppy.
BadDog 11-19-2004 04:49 PM
Check with those companies that make the pre-cut vinyl letters. They may be able to make you a reverse one that you could use as a template for light sandblasting followed by airbrushing.
Reed Jensen 11-20-2004 09:57 PM
I had mine engraved... then anodized... then the engraving was "filled" with baked in white enamel.. I don't know who does it in your area... but I can tell you who does it here in Los Angeles... :D
38KV 11-21-2004 06:31 AM
2 Attachment(s)
I CNC-milled them out of anodized 1/8" aluminum. In that way, the letters became silver (aluminum) colored.
mcollinstn 11-21-2004 07:34 AM
If you use plastic with a translucent center, you can backlight it and the lettering will glow at night. That's what a lot of mfrs do. The little lillumination strips just stick on the back.
puder 11-21-2004 06:22 PM
i did mine out of i believe 1/8 might have been a littel thicker but certainly not 1/4 mine also support the steering.
tcelano 11-21-2004 06:40 PM
I built mine during a recent overhaul of 1/8" Aluminum with excellent results. It is thick enough to machine well, but any thicker would be overkill.
Lofty 11-21-2004 08:06 PM
I can get you one made, engraved and painted. What's the boat and how do you want the panel laid out. I've got great deals on pre-fab'd panels. Give me a call or email.
Finn
510.541.8124
pachangalpina 11-22-2004 07:46 PM
I have made several fountain panels and powder coat them front and back. After powder coating them, I laser engrave them which cuts through the powder coating and leaves the silver aluminum lettering and logo. I can also custom engrave the billet steering centers and various other anodized or powder coated parts.
Todd
puder 11-23-2004 02:20 AM
haha "finn" what teh normal spelling woudl cuase too much confusion!!!
Lofty 11-23-2004 11:29 AM
Poodar, Hey YOU'RE giving me a hard time about MY spelling?!?!?!
You think I'm gonna' spell my name right? No f'n way! Yes, that would cause waaay too much confusion.
puder 11-23-2004 11:54 AM
heheh
yeah definatly not pronounced like its spelled (threw me for a loop)!
Poorsche 11-23-2004 01:33 PM
2 Attachment(s)
Finn
Here is pic of my current dash and my boat--
Would like to cover the entire guage panel, trim indicator panel and trim switch panel with a yellow material to match the other trim on boat. I sent via email but not sure if they went from this machine at work.
Poorsche
www.boatmat.com
