-   -   1995 454 Magnum EFI internal specs??? (https://www.offshoreonly.com/forums/general-q/90995-1995-454-magnum-efi-internal-specs.html)
Wally 11-23-2004 02:02 PM
OK, i'm sure this may have been talked about before but i cant seem to find anything useing the search no matter what combo i put in it......so my question is: What does a 1995 454 Mag EFI motor have in it??? Are the heads rec or oval port? forged crank? Good rods? Forged pistons? i know its a roller motor...fill me in here! :D
BURNSMAZZ 11-23-2004 02:15 PM
Re: 1995 454 Magnum EFI internal specs???
Everything you just said rectangular port heads,forged pistons,hydraulic roller cam,forged rods,four bolt mains,it's good stuff.
Wally 11-23-2004 02:52 PM
Cool thanks......do you know if it has a serpentine belt setup? or the v-groove still for that model year?
Pat McPherson 11-23-2004 06:35 PM
A 1995 is likely a Gen V not a Gen VI. I believe 1996 is the transition year.
It is easy to tell, does it have a 6 bolt or 10 bolt timing cover? If 6 bolts, Gen VI roller...
It has V-belts; my 1997 still has V-belts.
The rest you have right, rec heads and good forged internals...
