-   -   Can you remove water from the filter (https://www.offshoreonly.com/forums/general-q/91575-can-you-remove-water-filter.html)
David Haag 12-02-2004 07:54 AM
If water gets into the fuel/h2o canister filter can it be removed by dumping it out and reusing or do you replace it. We recently had flooding here and I am worried water might have work its way into the fuel tank through the vent.
mcollinstn 12-02-2004 07:58 AM
Re: Can you remove water from the filter
Whilst removing known water from the tanks, you can indeed run and dump, run and dump, repeat...
Once you've got most of it out, you should then put a new separator on. The cellulose in the media gets water in it and it won't dump out.
JIMG 12-02-2004 08:08 AM
you can also install a racor filter on the same filter head with a metal bowl & a drain plug in the bottom. A little pricey but it is a great filter.
