-   -   TRS vs BRAVO (https://www.offshoreonly.com/forums/general-q/91667-trs-vs-bravo.html)
CN24 12-03-2004 10:58 AM
TRS vs BRAVO
Is the distance from the crank shaft to the prop shaft on a TRS the same as on a Bravo?
IRONMAN 12-03-2004 12:57 PM
Re: TRS vs BRAVO
I measured a little more than 2 inches shorter.
jpclear 12-05-2004 05:50 PM
Re: TRS vs BRAVO
I'm guessing that Ironman is saying that the Bravo is about 2" shorter from drive input C/L to prop shaft C/L than a TRS. That right?? --- JP
Edward R. Cozzi 12-05-2004 07:49 PM
Re: TRS vs BRAVO
Am I misunderstanding the question? What about the transmission?
jpclear 12-06-2004 11:06 AM
Re: TRS vs BRAVO
Crankshaft C/L and drive input C/L should be the same; transmission or not. I'm assuming that we are talking about a verticle dimension here. --- JP
27 MAGNUM 03-18-2007 12:00 PM
Can anybody get me Crank line center to top of Transom Plate on TRS vs Bravo, I know this question dose'nt make sense, but it will cure my curiosity. I have a picture that shows TRS mounted at the rub rail from the Factory, I would like an idea of where the X was stock.
