-   -   Intercoms/WHAT IS THE BEST DEAL? (https://www.offshoreonly.com/forums/general-q/91707-intercoms-what-best-deal.html)
plumbers crack 12-03-2004 08:05 PM
wHAT IS THE MOST POPULAR ?PRICE?HOW GOOD IS THE STEREO WHEN PLAYED THROUGH THE HEADPHONES AND SO ON? tHINKING ABOUT INSTALLING ON NEW BOAT.
plumbers crack 12-05-2004 02:56 PM
Re: Intercoms/WHAT IS THE BEST DEAL?
helloooooooooooooooooooooooooooooooooooooooooooooo oooooooooooooo?
ThunderChris 12-05-2004 04:04 PM
I installed the Revolution Marine Intercom system in my boat this summer and it has worked very well.I had a couple of problems with the main box,but the owner was very helpful and fixed the problem with no questions asked.I tried both the boom mike and the throat mike and decided to go the throat style.They were a little uncomfortable at first but you get alot better reception and alot less wind noise past the 80 mph mark.The stereo comes in clear but sometimes it is hard to hear.I think the system was around $1800.00 for a 4 man system.The system was very easy to install and had more then enuff wiring for the boat.I would recommend this system to anybody looking for a intercom.
Sight and Sound 12-05-2004 09:40 PM
Tigerperformance systems are the best on the market. I have installed these systems before. The common problem is not hearing your stereo through them very well. The fix for that is to install a line drive on the rca output that runs from the main intercom box to the stereo. The line drive will boost the level that comes from the stereo to the headphones bringing the audio level up to a useable level. Without the line driver you have to turn the squealch up real loud to here the stereo which works for that, but as soon as someone talks over the system, their voice is way too loud. The line driver is just simply a boost for the audio signal. I believe that Tigerperformance includes a line driver now in their packages just for that very reason.
dyno 12-06-2004 05:04 AM
I have an aviation set-up that works fine for less than $400....
TomFTM 12-06-2004 01:57 PM
Dyno , Do you have any info on the avation system you have? Thanks, Tom
dyno 12-06-2004 02:55 PM
I bought them from Gulf coast avionics, I have a portable setup they have panel mounted also. They are on the web along with several other pilot shops just surf around, Sportys pilot shop is another I can think of. I love mine they take all the wind noise away so I can hear the engines better as well as my passengers. If you have any wind sheild they work fine if you take tons of wind you can get throat mics and that goes away but I'll bet you get a funky tanline... :D If you are ever in West Michigan I'd let you try mine before you buy.....
plumbers crack 12-06-2004 05:58 PM
Thanks for the replies!I thought the passengers would get a kick out of being able to talk and listen to the tunes without screaming and turning the mute button on and off.Sometimes you want to hear the engines and then the music.But $2,000 bucks,I could get bigger amps and f the passengers
BRUCE SEROFF 12-06-2004 06:08 PM
http://www.boatcommunications.com/bo...boat_main.html
http://www.sampsonracing.com/sampson...new/home_f.htm
http://www.racingelectronics.com/marine.html
bob 12-19-2004 05:16 PM
Has anyone ever tried the Flight Tech Intercom? So cheap, maybe too good to be true?
Crazyhorse 12-19-2004 06:14 PM
Gulf Coast Avionics, Sporty's Pilot Shop, Pacific Coast Avionics, and a myriad of other places, all with websites, are around for the people shopping for portable units and headsets. I also have a portable 4-place unit that I use occasionally.
Quiet Flite makes a really nice panel-mount stereo unit with celphone input as well as music inputs.
Sigtronics also offers panel-mount intercoms and installation kits. You may be able to buy sealed units for marine/open cockpit applications.
Ted G 12-19-2004 11:14 PM
Just saw this the other day, seem to work o.k. in the store, good low cost alternative.
http://www.radioshack.com/product.as...%5Fid=20%2D285
