Vortecs to IronEagle200?
Well, after gaining 9mph, there is still need for a speed.
I thought that Iron Eagle heads w/200cc intake volume might give some more power from 3500rpm up, without losing too much from low end? Engine is 350/330HO w/crane cam 109821, Air-Gap intake, BG650 carb, 9.3:1 CR, made 385hp@5200rpm & 450lbs@3200rpm on dyno. DeskTop2000 shows that there could be near 30-40hp more with 200cc heads? Chris & rmbuilder, like to hear your opinions, as well others with knowledge of real engine results? Thank you, S-24 |
Re: Vortecs to IronEagle200?
S-24
What heads are you currently running? Bob |
Bob,
I`m using stock vortec heads w/1.94" & 1.50" valves. Only work on heads is; removing sharp edges from chamber, unshrouding valves by head gasket, blending the throats, reshape guides, 1 hour work total on both heads. And of course machined guides to work w/higher lift cam. I was thinking of use the same cam, w/1.6:1 rocker arms. S-24 |
| All times are GMT -5. The time now is 01:02 AM. |
