-   -   bravo one drive resivoirs (https://www.offshoreonly.com/forums/general-q/92213-bravo-one-drive-resivoirs.html)
SKRAMER 12-11-2004 10:06 AM
I'm thinking about putting gear lube resivoirs on my bravo ones. They are 1999's and have the port for the resivoir but my boat doesn't have them. Can anyone tell me where I can get them and how hard they would be to install. Thanks Scott
Biggus 12-11-2004 10:33 AM
Re: bravo one drive resivoirs
Are you sure you have '99 transom assemblies? Because they did not use a gear lube reservoir on the 1988 (first year) Bravo drives.
My guess is that you have the '88 transom assemblies. If you had the newer ones and there was no lube res. connected you would have gear lube in the bilge.
...unless the lube hose inside the boat was plugged.
TxHawk 12-11-2004 10:48 AM
I agree with Biggus. If you had a spot for them and no res. you would have the lube spilling out.
aero-offshore 12-11-2004 10:53 AM
The tube is probably blocked off like mine are. I'm interested in putting a res. on also. I think all you need is a oil res, and hook up the tubing.
formula31 12-11-2004 10:54 AM
If they are 88's, I can show you how to connect res. up to them.
CMG 12-11-2004 12:07 PM
http://www.mercstuff.com/reservoir.htm
Strip Poker 388 12-11-2004 12:25 PM
Originally Posted by CMG
The old round style I have had problem cracking and leaking . I am trying to find a better ,larger reservoir.
Biggus 12-11-2004 02:22 PM
Check out the reservoirs from Revolution Marine.
www.revolutionmarine.com
SKRAMER 12-11-2004 03:02 PM
I have a black tube that is blocked off screwed to my transom. I'll bet that is what it is for. I always wondered. So if I connect a reservoir to it. it will probable work. I'll check it out on monday. Thanks for the help, and the web site. Scott
Strip Poker 388 12-11-2004 03:23 PM
Ck out this dealer of the resivors . i have never heard of them
http://www.davidwademarine.com/index.htm
