-   -   HP500 Drain plug thread size? (https://www.offshoreonly.com/forums/general-q/92376-hp500-drain-plug-thread-size.html)
NW_Jim 12-13-2004 07:09 PM
Need to install some oil pan drain hose kits on a pair of 1998 HP500's I can't easily pull the plugs right now to measure them. Are they 1/2-20 or metric? Please be absolutely positive. No guesses please. :rolleyes:
Also any suggestions for the best source of these hoses. I have gotten them through Eddie Marine or CP Marine before. I would sure like to find some that didn't use brass threads.
Thanks,
Linster 12-13-2004 08:40 PM
Re: HP500 Drain plug thread size?
12mm.
The brass end that comes with them will strip real easy. I would suggest getting steel one made. I stripped one with hardly noticing. I decided not to use them until I came up with something better.
NW_Jim 12-13-2004 08:48 PM
Thanks Linster,
If you notice the last sentence of my post, I have recognized that problem. If something goes wrong after install, that means an engine gets pulled. I would sure like to find a source for something better. Anyone?
NW_Jim 12-14-2004 08:05 AM
Maybe something made out of Cres?
