-   -   So what is the limit of #6 drive? (https://www.offshoreonly.com/forums/general-q/92574-so-what-limit-6-drive.html)
gripit 12-17-2004 09:58 AM
Re: So what is the limit of #6 drive?
Where can you buy #6 drives and how much do they cost? Can you swith from TRS to #6 as an upgrade?
The Menace 12-17-2004 10:05 AM
#6's are north of 25g's and most dealers are north of 30 g's.
Mercruiser dealers can order them.
Any drive can be replaced by any other drive if the rigging is performed properly. Rigging may require the X dimension to be changed, positon of the engine in height and also maybe set forward or back. The transom holes may have be made larger or worst case scenerio, the transom plate may have to be completely filled in and recut.
Lots of work but very feasible.
The Menace 12-17-2004 10:08 AM
Originally Posted by ratman
expresscat, worked for gm for years. seen any fast boats with ford or mopar power lately? nuff said. ratman
Good point. I didn't think you were an exterminator but I had to ask the opportuntiy was too good to pass up.
