What model outdrive is this?
1 Attachment(s)
Is this a bravo or an alpha?
Re: What model outdrive is this?
Still Cant See It.my Guess Is A Bravo,alpha,s Wont Run Stainless 4 Blades For Long.
hard to tell cus of the angle its at but i'm gonna go with alpha the upper gear case looks to small to be bravo, thaat and teh baot has the littel gimpy trim tabs and they can usually be foudn with alphas
AND that prop loosk lieka revolution not a bravo1 4 blade. And revs are usually foudn on alphas. |
It apears to have the rear cover ,Bravo
whats it have for power - small block?? |
1 Attachment(s)
377 Scorpion
Centerline on exhaust looks small block.
bravo 1 one the back cover bolts give it away. it is tricky with that picture though. the tie bar also gives it away an alpha one gen II uses e-clips and push on plastic end caps.
377 scorpion would be factory mated to a bravo
| All times are GMT -5. The time now is 10:50 PM. |
