-   -   power for electric fuel pumps ? (https://www.offshoreonly.com/forums/general-q/93013-power-electric-fuel-pumps.html)
boatman747 12-30-2004 06:41 PM
Re: power for electric fuel pumps ?
thanks for the help fellows
Mike L 04-24-2007 08:56 PM
Where do i get the correct relay?? I need two of them, i bought a boat and it was hooked to the purple wire of the coil. I want it changed to be correct.
Mike L 04-24-2007 08:57 PM
if you connect the relay directly to the battery wont the pump run all the time? And how do i wire it into the oil preassure switch?
CCstinger260 04-24-2007 09:34 PM
The relay will only let electric go to your fuel pump when it gets juice from the coils or ignition switch or oil pressure sending unit, whatever, to close the contacts. A relay is just a switch. You "turn on" that switch by supplying electric to it instead of manually moving a toggle or pushing a button. The power that runs the fuel pump is separate from the power that causes the contacts in the relay to close (and make the fuel pump turn on). I know that's not very clear, but I hope that helps...anyone else wanna try?
ROB FREEMAN 04-24-2007 11:05 PM
summit racing
get one for summit racing and a 7lb oil switch its simple set up cost you 50 bucks to youre door
Mike L 04-25-2007 06:51 AM
Can i hook the oil pressure switch to my external oil filter. It has a spot on the bracket that i could use for the switch. This should have preasure here.
29scarab 04-25-2007 07:59 AM
You should be able to put your switch there. I put my oil temp gauge there myself and screwed my oil pressure switch into the back of the block by the distributor. My oil pressure sending unit is located by the oil filter bose where the remote lines hook up to come up to the filter. Someone may chime in on what side of the filter to put it on.
Good Luck!!
Mike L 04-25-2007 06:35 PM
The block where there is like a 1/4" plug? I have a oil switch but i think i fried it.... Can you blow air into the oil safty switch to make it trip? I had it all hooked up and grounded and i was trying to make it trip the relay but couldnt
Mike L 04-25-2007 06:36 PM
Actually i am looking at the intake manifold where there is a plug near the distributer.
Mike L 05-01-2007 06:08 PM
my electric fuel pump quite working out on the water. took it off because i thought it burned up after running it off the coil, but it works now when i hook it to the battery. I have perfect 12 volts at my hookup on the boat. Can fuel pumps overheat and then work again?
