speed calculations
What kind of top end speed should be anticipated from a set of 30 inch bravo ones spinning 5300 in a formula 311 1988 no step. (1.5.1 out drives bravos )sHOULD i CHANGE GEAR RATIOS.? iS 1.5.1 HARD WITH A 30 INCH 4 BLADE ON AIR TIME / REENTRY ?
Re: speed calculations
You must have some serious HP in those motors. With no slip factor your at 100mph. 10% slip would put you at 90.
Throttle control is the biggest factor in weather or not your going to tear up drives or not. With the kind of HP you must be pushing to spin the 30's @ 5300 on that boat I think drives are going to be an issue. |
I always used RPM divided by gear ratio, times pitch, divided by 1056, I've seen as
much as 18 percent slippage, borrow a GPS, and be sure. |
much as 18 percent slippage, borrow a GPS, and be sure. 5280/5=1056 same way to get there... |
Originally Posted by JCPERF
RPM divided by gear ratio times pitch times 5 divided by 5280 minus slip[10%]
stepped? pad? cat? i would think they would vary greatly.... i haven't done much w/ speed formulas so i was just wondering.. |
Originally Posted by Sean H
does hull style vary this greatly?
I have 30" labbed turning on 1.5 Ratio drive at 5200 I run 81 mph. Straight V. 650 HP.
I have read that 30" is the most efficient pitch on a bravo outdrive. |
I ANTICIPATE BETWEEN 80 AND 85 SOMEWHERE . Waiting on another warm day for a test ride !!!
| All times are GMT -5. The time now is 06:53 PM. |
