-   -   Hydraulic roller cam question (https://www.offshoreonly.com/forums/general-q/93473-hydraulic-roller-cam-question.html)
Comanche3Six 12-30-2004 09:21 PM
572 cubic inches, supercharged. 1000 rpm idle, 5000 rpm maximum.
What billet hydraulic roller cam is best suited for this engine?
mcollinstn 12-31-2004 12:45 PM
Re: Hydraulic roller cam question
Haven't really given us a lot to go on.
If you have stock-ish heads, you'll need duration numbers up in the 245@050" range. Lift numbers over .600 won't help you any.
If you have aftermarket heads, you can go with less duration, more lift.
Comanche3Six 12-31-2004 02:10 PM
Dart Iron Eagle Heads 345cc intakes
