-   -   power curves (https://www.offshoreonly.com/forums/general-q/93872-power-curves.html)
Stormrider 01-06-2005 07:32 AM
power curves
Any one have the power curves for an HP500 and/or 525efi?
If not the graph, then just the data will be fine.
articfriends 01-06-2005 06:32 PM
Re: power curves
Find jeffs post (wags 382) called cam help with afr 305 heads about 3 pages back from here,he just dynoed his hp 500 carb motors for before results and if you read thru thread he posted his dyno results(and i might add he made around 530 hp! with 200 plus hour motors turning all his accessorys etc),Smity
WAGS382 01-06-2005 07:00 PM
Re: power curves
1 Attachment(s)
Here you go.
RLW 01-06-2005 07:14 PM
Re: power curves
Invalid Attachment specified.
If you followed a valid link, please notify the webmaster
RLW 01-06-2005 07:20 PM
Re: power curves
Okay, it's fine now.
I like the nice flat torque curve along with it's starting and ending rpms.
It should be interesting with the 305's. Is there a cam change being considered?
Russ
WAGS382 01-06-2005 07:36 PM
Re: power curves
Russ,
Yes I picked out a new custom ground cam and talked to Bob Madara after the fact and he liked the specs. I would be very happy if I can get 1.33 hp/cid like you did, but I have a much more conservitive number in my head and it is over 600 .
Stormrider 01-07-2005 07:28 AM
Re: power curves
Wags, thanks for the post... just what I was looking for.
was that dyno was done before any mods?
WAGS382 01-07-2005 04:16 PM
Re: power curves
Stormrider,
The only thing I did was mill off the choke horn and do some mild blending in the carb. These are 1998 factory sealed HP 500's with 270 hrs on them. I never even changed the ignition timing. Jeff
