-   -   Hull problem??? (https://www.offshoreonly.com/forums/general-q/93982-hull-problem.html)
kennywould 01-07-2005 06:04 PM
Hull problem???
Anyone having trouble with porposing on their 27' Baja's, or any other quirks? What was the cure if you happened to fix it?
My hull starts its porposing about 70 mph, with the tabs neutral it quits but I lose about 2 mph at top end, over 75 if you pick the tabs up it you pick up speed but the porposing is a lot worse! :( :(
WETTE VETTE 01-07-2005 06:27 PM
Re: Hull problem???
Most Bajas have a pretty generous radius where the boats running surface and transom intersect. If that is squared off it will likely help the porpoising. It will also make the boat run flatter which can hurt your top end depending how fast you run. If you are getting into the 80's or 90's you are probably running on top of the water enough that a small loss of bow lift won't hurt your top end speed, and it may even improve. We have done this on smaller Bajas running 80+ and the overall performance was much better with no top end change.
Craig
kennywould 01-07-2005 06:42 PM
Re: Hull problem???
-Craig
Thanks, I did sand that once before but maybe not enough, I'll try it again since I have the motor out and the drive off, will make it easier.
-Ken
WETTE VETTE 01-07-2005 08:49 PM
Re: Hull problem???
On ours sanding wasn't enough. We actually had to use some filler and re-paint. I don't know if this will solve your problem, but take a look at other hulls and compare the Baja radius and you will see the differance. Baja is a good boat, but most of their hulls are not manufactured to run much faster than what they can do with stock power. Look at Eliminator, or Fountain and that trailing edge is pretty sharp. My 1990 Baja 210 ESS ran in the upper 90's, and needed some mods to do it. :cool:
kennywould 01-07-2005 09:38 PM
Re: Hull problem???
I do remember seeing the edges on an Eliminator, I will take that into consideration, Thanks again
GPM 01-07-2005 11:10 PM
Re: Hull problem???
Was that Eliminator upside down when you saw it?
Griff 01-08-2005 03:51 AM
Re: Hull problem???
What prop are you running and what HP engine?????
Hang Time 27 01-08-2005 12:27 PM
Re: Hull problem???
Yep, I'd try diff style prop. If your running round ears like a mirage, try a hydromotive with semi cleaver design, and vice versa. Sounds llike more bow lift of the cleaver is what you need. It will either make it better, or worse, and you don't always know till you try it on your boat.
GPM 01-09-2005 10:25 AM
Re: Hull problem???
Isn't a clever prop for transom lift?or less bow lift.
Hang Time 27 01-09-2005 03:04 PM
Re: Hull problem???
Uhhhh..... yep, meant to say "transom lift" in #8 above.......sorry......gonna have to proof-read more often!!!!
