-   -   How much HP can "new" Bravo's (https://www.offshoreonly.com/forums/general-q/94067-how-much-hp-can-new-bravos.html)
Scott B 01-08-2005 10:49 PM
handle???
Looking at 600 HP, mucho torque........
KAAMA 01-08-2005 10:57 PM
Re: How much HP can "new" Bravo's
Scott.
There must be a 1001 threads on the Bravo One drive within the archives of OSO. Do a search on the Bravo drive as this question seems to get asked quite often. You will find a TON of info.
The Menace 01-09-2005 06:29 AM
There have been sveral threads on this subject, one more will not hurt.
RIce Hauler had 625 Zul's, never lost one.
I have (had) 600 hawks and twisted the prop shafts like candy canes after 125 hours.
I now have 700's being installed this week. As long as I do not do hole shots, slam the throttles like a dragster or try to to get air time like an airplane (keep them in the water) I do not anticipate any problems.
If you want to run like a maniacle race boat driver, install IMCO drives or 3's or higher.
Scott B 01-09-2005 08:18 AM
I saw some prior threads, but they were the old style Bravo's. And, agreed, the driver is the key, I have sen them hold up on 800+ HP blower motors, and get blown up behind stock 454 Mags...
I'm curious about the new "Volvocruiser" version. I have an opportunity to buy a B-1 complete, looking to put it behind 600 + HP and a bunch of torque.... Did not se a thread about them yet
Jassman 01-09-2005 08:23 AM
1 Attachment(s)
I had KE675s on a 37 A.T. Blew up a few, part of the reason I blame now was cause when put into nuetral, the engine rpms would spike up to 1300rpms. TMP fixed the KE's, you have to wait 10-15 sec. before they go back down and then engage forword or reverse. Very hard when docking. Im sold on anything with a tranny, No more bravos for me. Jeff
Scott B 01-09-2005 09:51 AM
J,
Yeah, that's another part of the equation for me.. Different ballpark maybe, same equation..
I currently have a TRS, thinking of either the Bravo or scrapping the Merctrans and going to a BAM or Velvet drive and keeping the TRS...
Nordicflame 01-09-2005 09:55 AM
I think the question here is the "BRAND NEW" style Bravo. 2005 version, not the old stand by... :D
Jassman 01-09-2005 10:29 AM
Not enough of them out there with real hours to make a judgement call. Has the upper/lower internals been changed, hopefully they are beefed up. Jeff
Scott B 01-09-2005 09:36 PM
Correct.. I'm told the limits are basically the same, the B-1 limits out @ 500HP, B-XR limits out around 625.
Guess I'll be sticking with the TRS for now...
Back4More 01-10-2005 10:49 AM
Just make sure you prop it on the back side of the TQ curve at WOT.
RLW 01-10-2005 06:27 PM
Could you clarify?
offthefront 01-10-2005 08:41 PM
Originally Posted by RLW
Could you clarify?
yea do that ...
HighPriority 01-10-2005 09:03 PM
I think what they are saying, is that big props.are hard on the drives.
jaroot 01-10-2005 09:33 PM
skunkworks there scottyboy???? :evilb:
Scott B 01-10-2005 09:40 PM
You saw the boxes..
You knew I'd unwrap em..
Then what did ya think I was gonna do??? :drink: :eek: :D
Byrdman 01-10-2005 09:49 PM
The TRS drive is a good old drive..can handle power and abuse...you can put the 600 on it with no problem. Back in the day they used to put more power than that on them racing and drive failure was never a issue..never!
Back4More 01-10-2005 09:58 PM
If you prop your WOT rpm too low or too close to your TQ peak of the motors it will tear up the drives that much easier.
Jassman 01-11-2005 06:42 AM
Originally Posted by Troutly
What, are ya new!? :p
I knew someone was going to catch that, I should have guessed it would have been you :D The hard part was trying to dock, waiting for rpms to come down. :eek:
Scott B 01-11-2005 10:16 PM
If you like that, try docking a Donzi Blackhawk :eek: :eek:
cooltoys61 01-12-2005 09:48 PM
Higher pitched blades = flatter smack on the water when not sync'd with boat speed/rpm. Lower pitched=slice into the water easier no matter the mismatch. Add to that the more direct route of the power to the water on a high pitch as opposed to the "buffer" of more gear ratio from a small prop. Add to that the need to flog big props to get out of the hole. But hey,you can't beat the cruise speeds.
Scott B 01-13-2005 05:27 AM
Dude, wanna put down the pipe a moment and explain that?? :confused: :confused: :confused:
BadDog 01-13-2005 05:52 AM
I understand Scotts logic completely, on paper. How much difference it makes is debatable and is likley offset in one way or another, by size of gear teeth and other mechanical differences.
As far as his statement envision smacking a canoe paddle into the water horizontally, now try it with the paddle at a 90 degree angle to the water.
BadDog 01-13-2005 05:53 AM
Woops, Cooltoys logic...
50boat 01-25-2005 10:43 PM
ive ran 750 hp on a 96 42 fountain four 4 years no down time yet,,, afrend runs 875 hp blower mots on a32 baha no down time,, 40 baha tripplehp 500 trashed --7--- drives in 14 months. ithink its the hole shot ore air time that does it. although i love to jump cruser wakes like a jetski. so how knows
cuda 01-26-2005 07:44 AM
Scott, is this for the Critter?
Scott B 01-26-2005 08:45 PM
X boat :eek: :eek:
jaroot 01-30-2005 08:06 AM
Originally Posted by Scott B
X boat :eek: :eek:
honestly scott, i could just "detune" the 16 to make you feel better :evilb:
Root - die alpha die
Scott B 01-30-2005 08:46 AM
LOL, I'm already hearing rumours about your winter detuning project..
When do you want my SSM's for the dyno pulls BTW??
ECeptor 02-02-2005 08:09 PM
Here is some info on old vs new Bravo 1's - http://go-fast.com/mercruiser_bravo_sterndrives.htm
As to the big prop vs little prop discussion above, it's all about the damage to the powertrain - powertrain being everything from the engine flywheel to the prop.
Here's the deal - powertrain damage is quantified as load^exponent times rate. In a mechianical transmission like a boat drive it's torque^exponent times rpm. The exponent used depends on the failure mode and can be either 3.33, 5.66 or 8. So, let compare a couple of way of putting 600hp through a drive. First is a warmed up 540ci belting out 600hp at 5000rpm which requires 630 ft-lbs of torque. Second is a high winding 502 producing the same 600hp but at 6000rpm would require 525 ft-lbs of torque.
OK, now let's use the lowest exponent, 3.33, and see the difference in damage between the two set-ups.
The 540 is 630^3.33*5000=1.05E13
The 502 is 525^3.00*6000=6.87E12
Therefore the lower rpm 540 would have +53% more powertrain damage than the higher rpm, lower torque 502! This change in damage relates 1:1 to the life of the drive.
Moral of the engineering story? If you want to keep you drive alive, keep the torque low and rpm up to get the power to the prop!!!
I almost forgot - this is ASSUMING the drive is sufficiently designed so the failure is in fatigue and not low cycle. Put 1000hp in front of an Alpha 1 and all bets are off!
