water pressure
What should be the water pressure if there is no stat and no water pump(just a sea water pump) and a cross over i tap the water gauge to the cross over? i have 25psi now is that to much?? at wot.
Re: water pressure
In my mind, 25 psig is the limit at WOT. I have a Mercury Racing pressure relief valve on my engine and the most I see is 22 psig. It is the spikes that you have to be concerned with. The PRV that I use pretty much addresses that issue.
Russ |
Re: water pressure
I'm surprised you get that much w/o a t-stat installed. You might find the pressure a bit lower if you tapped into the block itself, eliminating the resistance from the 2 crossover to block holes.
Re: water pressure
I thought it was a little high i was gonna put in water dumps to lower it.
i do have gil exhaust. |
Re: water pressure
Take a pressure reading form the engine block to get an accurate reading.
| All times are GMT -5. The time now is 09:21 PM. |
