desk top dyno
i would like to see the curve on hp and torque of these two cams.
crane 168731 val. lift int 587 ex 610 adv dur 288/298 @ .050 226/236 lc 112 isky 696275/284 grind#rr275/284 val. lift int 553 ex 578 adv dur 275/284 @ .050 228/238 lc 112 motor is a zz502 9.6:1 comp alum head oval 110 cc air gap intake edelbrock dual plane holley carb 4150/4781-5 850 cfm hei ignition (gm) (deg adv ?) exh lightning header I enderstand it wil be only bal park result thank you. |
Re: desk top dyno
I'll run it for you this afternoon when I get home from work.
Re: desk top dyno
apreciated,i'll check result sometime tonight.
Re: desk top dyno
How acurate is a desk top dyno ?
Re: desk top dyno
My desk top dyno was real close to my actual dyno #'s. However, you need real good data to get accurate results from the program. You really need the flow #'s.
Re: desk top dyno
I just saw the software for 49 dollars. Does this sound correct ? If so its worth it .
Re: desk top dyno
Sorry it's taken me this long to get back with you but I just got home.
Please list the cam card info if you have it. DD requires the input of the cam timing events. Thanks. |
Re: desk top dyno
I'm sorry i don't have the cam timming card.
wonder if anyone does ? I'll do some researche and see what i can find,sorry about this! |
Re: desk top dyno
Awesomerott,
Here are the head flow #'s for the GM aluminum oval heads. The far right # are exhaust w/pipe 0.2 138 119 86% 122 0.3 193 145 75% 156 0.4 233 168 72% 178 0.5 272 189 69% 194 0.6 299 202 68% 207 0.7 318 210 66% 213 |
Re: desk top dyno
Cam timing @ .004 for Crane 168731. I believe DD2000 asks for timing @ .006
Cam Timing: TAPPET @.004 Lift: Opens Closes ADV Duration Intake 33.0 BTDC 75.0 ABDC 288 ° Exhaust 82.0 BBDC 36.0 ATDC 298 ° Bob |
Re: desk top dyno
thank's for the #s.
what do you think of this DD,just curios. |
Re: desk top dyno
were can i learn how to read these #'s and what it mean.
Re: desk top dyno
Isky rates adv dur for Hyd roller @.007 so trying to DD this with adv #,s will be invalid as valve events will not be comparable. Thats what leads to false output with these programs. Your only apples to apples would be the .050" numbers.
Isky 228*/238* 112*LSA 112*ICL IVO 2* BTDC IVC 46* ABDC EVO 51* BBDC EVC 7* ATDC Crane 731 226*/236* 112*LSA 107* ICL IVO 6* BTDC IVC 40* ABDC EVO 55* BBDC EVC 1* ATDC Keep in mind the Isky is straight up while the Crane is 5* adv. Changing your center lines will alter the valve events so use these as a baseline Bob |
Re: desk top dyno
If you advance the Isky numbers 5* they are nearly identical with the Crane
IVO 7* BTDC IVC 41* ABDC EVO 56* BBDC EVC 2* ATDC As you can see this is where the output on the computer sims gets very skewed, very quickly, many times without the user even knowing. Its been said that they are useful in predicting "trends" like peak TQ/HP placement, VE, etc but, in my opinion, I would never seriously consider component selection, especially camshaft profiles, based on the output. Bob |
Re: desk top dyno
bob i think i enderstand wath you mean about DD.
is there a simple way to explain how this motor would perform with these two cam ? |
Re: desk top dyno
To clarify my last statement re; cam selection. Because there is not a set uniform standard for rating seat duration (a very important number), lobe area, accurate duration ratings @ .020/.100/.150/.200 etc your sims is really just giving a guesstimate at the actual lobe profile. Your very (expensive) advanced computer modeling programs utilize sophisticated cam measurement specifications in units of measurement in/deg at multiple points of lifter rise.
Re: desk top dyno
DD is a nice program to use when comparing parts from a baseline model. I like to use it and see how close the actual dyno results are.
rmbuilder, thanks for the cam specs. I appreciate it. |
Re: desk top dyno
By examining 10 different intake lobes with the same duration in detail (example 280* seat duration intake lobe) with a CamDoctor program at multiple lifter rise points, it illustrates that single point references can be very generic, and that the 10 examined lobes can be very different from each other.
Bob |
Re: desk top dyno
So unless you have extensive knowledge(like you and other) or expensive hardware,software it's very tuff to say wich one would work best when two cam profile are close.
Re: desk top dyno
Experience and knowledge base are important. In the case of the 2 very similar(duration) appearing lobe profiles you have inquired about the next step is to compare the lift figures(and requirements) which vary by about 10%, lobe intensity (rate of lifter rise), duration at .200", and lobe placement. Establish your valve events around your mechanical parameters, find the lobe that best fits within those events and you are much closer to an accurate choice.
Hope this helps Bob |
Re: desk top dyno
Sutphen30
They aren't especially forthcoming with that info (especially design information like lobe area). The end user doesn't ask for them and they aren't as "glamorous" as the head companies flow numbers. Bob |
Re: desk top dyno
Ok, here are some DD results.
Isky at 0 cam advance rpm hp tq 3000 362 633 3500 422 633 4000 475 623 4500 519 606 5000 539 566 5500 531 507 Crane 731, installed at 0 3000 371 649 3500 430 644 4000 478 627 4500 510 595 5000 512 538 5500 494 472 I entered the cam timing event data as published by rmbuilder. Thanks, Bob. If the cams are timed similarly (the 0 vs. 5 degree difference that rmbuilder pointed out) the numbers become virtually the same. Hope this helps you. Dave |
Re: desk top dyno
By the way, I was fairly conservative on cylinder head selection in the Desktop Dyno program.
Re: desk top dyno
Dave,
Thanks for the good work you did on this! Post #9 has some accurate flow #s on those(390) heads if you want to enter them into your data base. Bob |
Re: desk top dyno
thank's guys, realy appreciate your inputs and work.
Dave what do you mean by numbers become virtualy the same ? outcome on DD the same ? Bob, post #14,if you retard the crane of 5*,will it do the same,bring the crane #'s close to the isky #'s ? |
Re: desk top dyno
Well,read the thread again and still have a hard time to pick between the two.
i don't have the knowledge to analyze all those theories and #'s. |
Re: desk top dyno
I think what's confusing you is "the same"
What they mean is the HP/TQ curve are more down in the rpm range when a cam is advanced and up when it's retarded(backed off).One mfg quotes the "straight up" figures one quotes the advanced. Since you can adjust these when installing it doesn't really matter which they use,just that you know and compare them with the same advance.Look at how the Crane makes more power down low on rpm. If you installed the Isky advanced like the crane its power would move down the rpm scale. It's ALL a compromise, like everything. |
Re: desk top dyno
The other thing is,,if they are close you don't have to worry about picking because you will never be able to tell the diff between 520HP and 530HP.
Re: desk top dyno
thank's for the explanation Cooltoys.
something must happen today, some post missing from this morning. |
Re: desk top dyno
I wonder if someone could answer my question on thread HP500 valve springs checked ok/engine builder did not changed ? post #18
Re: desk top dyno
If you want to compute the timing events based on duration and lobe center, it is quite simple.
Let's try a single pattern cam first. For a number lets try 250 degrees duration on 112 degree lobe separation installed with 112 intake centerline(meaning straight up,no advance or retard). Divide 250 by 2 and subtract the lobe center(125-112) which equals 13. 13 is the intake opening event. Add 180 to that number and subtract the duration number again.(180+13-250) which equals 57. So intake opens at 13 btdc and closes at 57 abdc. Since it is a single pattern cam with no advance the cam specs will be as below. Code:
IO 13 EC 13Code:
IO 13 EC 18Hope this helps :) |
Re: desk top dyno
thank's Richard,it is simple.
| All times are GMT -5. The time now is 08:25 AM. |
