The real differences between 496Mag & HO
Being new to the boating world I found the most difficult decision after settling on a brand and model was what type of engine to get. With all the different engine options it'll make you :eek: Finally I decided on a Big Block, but which one? The MAG or HO? My Baja dealer wanted $7,500 for the HO upgrade. I found this to be outrageous. Having done some work on GM cars previoulsy I opted for the regular Mag496 375hp version instead, thinking that it would be cheaper to upgrade it in the long run.
So after my purchase I bought all the manuals from Mercruiser, including the Parts Manual. I took a highliter and went through every page hilighting only when there were different part numbers for the same part. Here is what I found. Decal HO pn#37-863307 vs. Decal Base pn#37-863306 PCM HO (Mechanical Throttle & Shift) pn#866091T01 vs. PCM Base pn#866090T01 Throttle Body Assemble HO pn#863379A06 vs. Base pn#863078A06 Camshaft HO pn#431-881628 vs. Base pn#431-881627 That's it boys & girls! A whopping 4 different pn#'s for and entire engine assembly and one of them's a sticker! :rolleyes: Some notes of interest. Same pn#s for ; fuel injectors, crank ( I was afraid that one might be forged while the other not), fuel rail and fuel pressure regulator kit. Different pn# for the throttle bodies but same hardware. (Source: Ray from Raylar) So now all I need is a solid contact for Mercuriser Parts to start arriving at my doorstep. Can anybody recommend somebody who sells parts cheap, like 10% over cost. Sebastien |
Re: The real differences between 496Mag & HO
Before you go wasting a lot of money upgrading your 375 mag to a 425HO, check out our website at www.raylarengine.com for some decently priced upgrades that will give you 525HP.
Ray @ Raylar |
Looks like the php/mysql dbase on the forum went down today. I'm going to repost some of the answers to questions which were posted on this thread earlier.
The PCM is a different pn# hence different programming. I recall reading from other members that the HO redline was 5,4xx rpm vs. the 5,000 rpm redline on my regular 496 MAG. Raylar, I have already bookmarked your web page. Congrats on a great product! However, I have to disagree with your original post as it being a waste of money to upgrade my 375hp to 425hp. If by replacing 3 factory parts I can gain 50 hp including a properly tuned factory PCM to match the cam and power output for the upgrades, then how am I wasting money? Your $5,800 package, a good tune, add $799 and now your at $6,500, or $65 per horsepower. So far I have acquired 2 of the 3 pieces (cam and new throttle body) I need for the puzzle and have only spent $250. Let's say worse case scenario the 3rd piece costs me full retail ($1,200) So thats $1,200 plus $250 equals $1,450 or $29 per horsepower. So how am I wasting money now? :( Also my 50 hp package has been tested on thousands of boats so it is safe to say it is a very proven upgrade. With all the 496 MAG owners doing supercharger upgrades, engine builds etc there will be a lot of manifolds, heads, camshafts, etc.. on EBAY or in various other classfieds that can be picked up at a very substantial discount over purchasing them from Mercruiser. In my case I have a forum member who is shipping me the entire intake manifold, pcm harness, throttle body, injectors, camshaft, 496MAG HO engine cover for $250 !!! This is why I love the internet baby! Happy Boating! Sebastien Sebastien |
The big difference is 50hp will net you about 1 mph. :(
:eek:
Shirley you can't be serious? :D |
Originally Posted by saubouin
So on my 24 foot Baja that weights 4,400lbs I'm only going to see 1mph on the top end?
Shirley you can't be serious? :D I dont know about you but 145hp made a huge difference to my boat at 4500lbs |
Shirley you can't be serious? :D Actually, you'll probably 2-4mph on the top end with 50hp. Been there, done that on a 24 Outlaw. Bumped a tired 365hp up to about 420hp and saw a 4mph gain. |
2-5 is more inline with what I'm expeting. If at the end of the day I only get 1mph I'll be a little bummed but will post my results nonetheless. |
replace the prop w/ a lab finished prop.
While you are doing all that work look into porting the heads. Wannabe |
Sebastien SmartCraft: Yes HP: 425 kW: 317 Displacement Liter/CID: 8.1/496 Cylinder/Configuration: V-8 Bore & Stroke (in): 4.25 x 4.38 Bore & Stroke (mm): 108 x 111 Compression Ratio: 9.1:1 Fuel System: MPI Full Throttle RPM Range: 4600-5000 Ignition System: PCM 555 Distributorless Where did you hear 5400 RPMs? The above specs are from Mercs website. I'm repowering with a 496HO. I was thinking I was going to have to buy a new prop too. I was running a 26 Bravo 1 at 5000 rpms with 385 HP. I think the extra 40 HP is going to bump me up to a 28P. If I can turn 5400 with this motor I probably won't need a new prop. Dave M. |
Stock rev-limiter is set at 5200 - 5250 rpm. You won't get to 5400 without a re-program. Whipple's stage one kit does it (5450 rpm) and you can still run 87 octane. Their stage two requires 91 octane but has a better power output.
Bounced Check,
Thanks for the update on the rev limiter on the HO. Also, I talked to Ray @ Raylar and he says the throttle body is the same on the HO vs. the regular mag and that is was only 7x mm ( I think he said 75mm). So although there is a different pn# for the throttle body opening between the MAG and MAG HO its really the same part. GM has been known to do this with its car lineup so it doesn't really come as a big surprise. Back to the throttle body opening. Is it really that small of an opening? Hell, the new V8 in the Vettes have a 90mm opening and that's a 6.0 SBC. Seems Like Merc is really holding back on the potential with this motor. I was watching a boating program on tv where they visited the GM plant making the 8.1 blocks. The bore to bore accuracy was pretty amazing. To illustrate blew up the thickness of a human hair so that it was 12inches across. Then they drew a tiny little circle inside the human hair indicating the accuracy tolerances. In summary it seems that the 8.1 MAG does have some strong aftermarket potential. But it remains to be seen if, at the end of the day, this motor can be built up to be as good or reliable as the mighty Blue 525 merc efi. I for one hope the MAG can deliver. |
Part of the HO upgrade also includes a stronger drive. You would have gotten the Bravo One X drive instead of the standard Bravo One if you had opted for the HO upgrade.
Re: Will the real 496 take a bow!
Just to put some facts in the stew. We just finished overseeing the installation of one of our BP103 kits on a bone stock 27 Ultra @ Absolute Marine in Lake Havasu, Arizona, Thursday and Friday. Boat was tested Wednesday at 0 t o plane time, 20-40 mph and 40-60 mph acceleration times and top speed mph. Prop was a labbed 24P 4 blade Bravo Conditions 70-75 degrees, very light wind chop and obviously fresh "cold" water. Boat results were taken with Garmin GPS, and stop watch. This boat is a big heavy 27 footer and has two extra monster 8D batteries alongside the engine to help run the 5000 watt sound system!!, 140 gallons of 89 octane fuel two people and about 50 lbs of gear. It's equipped with a Bravo X drive upgrade to Bravo XR specs and runs the stock Mercury exhaust manifolds with a drop elbow and out the transom. The boat before install ran 0 to plane 15 seconds ( not good) and top speed of 66.3 miles per hour honest GPS runs up and down wind average, no water current. Brought the boat to Aaron' s slick shop, they pulled the motor out of the boat ran a compression and leak down test on the motor, 155 to 160 lbs each hole with about 12% average leak downs on a 85 hour motor.
They removed the accessories, engine wiring harness and ECM, pulled the manifold, heads and camshaft and cleaned the surface of the block and checked for any visable piston , cylinder or ring dmage or obvious problems. None found. They degreed in the new cam, installed the new BigPower aluminum heads on our special Cometic head gaskets, installed the stainless roller rockers with our special AFN no adjustment locking nut and valves were set and ready to go. They installed the new Raylar "CoolGap" intake manifold, the stock throttle body, fuel rails, injectors, idle air motor, MAP and other stock sensors. We then installed our special fuel pressure adjustment bypass hose on the cool fuel system, installed all of the rest of the stock Mercury 496 brackets, accessories, bottles, hoses and what not. We then did our special modification to the stock Mercury exhaust manifolds and risers , filled all the fluids and installed the motor back in the boat. Hooked up all electrical, fuel and water lines, re-adjusted the fuel pressure setting and turned on the fresh water flush kit. The owner hit the key and she roard to life on the first crank and purred like a kitten! Check everything for leaks or problems, found a few hose clamps to loose, tightned and we were ready for Saturday test. Saturday was an awesome day at Lake Havasu, Arizona, clear light wind 75 degrees and an almost empty lake! Launched at the State Park ramp two blocks from Aaron's shop and again check for leaks, drips or errors, none found! Darrell fired her up we idled out of the ramp area and made the first 0 to plane test. 7 seconds!! Less than half Wednesdays base test. Tried it three more times same results! Thats with a 26P stock Bravo 4 blade prop. We then ran all of the acceleration tests, same results, less than half the time to same speeds. The "cou de gra" was about 6 peddle to the metal top speed runs with the motor roaring like a Lion for about one full hour. Average new top speed 76.6 miles per hour and we were htting the rev-limiter at 5200 rpms on each run! They will try and run the boat Monday with a labbed 28P Bravo 4 blade. Aaron and I feel 80 mph will be about a given! at 5000rpms and yes we had four people abord for the retest not two. Over 10mph increase on the limiter, acceleration times cut by less than half. I think this will just about say all that needs to be said about the 525Hp Raylar equipped 496 engine running stock exhaust and a totally untouched 496 ECM!! Gentlemen. Its nice what an honest 100+ horsepower and gobs of torque will do for a 496 engine. This may make it hard for some boaters to step up for 20K plus more HP525's in the future. The future of the Raylar 496 is awesome for OSO'ers who have these wonderful motors. Gentlemen, I will take your Qustions! The Bull**** stops, when the Green light drops! Regards, Ray @ Raylar |
Way to go Ray! Congratulations, those are some serious results.
Brian |
bn imagine doing this to your 31 sonic !!
863379A06 shows as a NLA part.. If it is the same as the Mag, that would explain it....
First post here on OSO.
My boat was the most recent Raylar project and the latest results from Ray has posted were from today. We spun a 28 blue loaner prop off the shelf and top speed was 79.8Gps & 79.4 Gps @ 5000rpms.The overall results for this project were awesome.Cut the time to plane in 1/2 and gained 13-14mph.What else is there to ask for.Raylar has delivered everything promised.Thanks Ray & Larry! |
Impressive results Ray :)
We are very proud to be a Raylar Dealer for Germany
Great Products - Great Power - Great Developement Congratulations Ray and Larry We already ordered 4 BCK 103 Kits www.496power.de |
| All times are GMT -5. The time now is 04:13 AM. |
