-   -   rev limiter on hp500 (https://www.offshoreonly.com/forums/general-q/94619-rev-limiter-hp500.html)
boatn70 01-16-2005 08:03 PM
looking at an ignition from a 1996 HP500, whats the rev limiter set at on one??
boatn70 01-16-2005 08:20 PM
Re: rev limiter on hp500
it is a carb motor
Griff 01-16-2005 09:04 PM
Thunderbolt IV ?????? or V ???
The rev limiter is a separate component on TB IV's and not built into the module. It may or may not be included with what you're looking at. It would be at 5300-5350rpms.
boatn70 01-16-2005 10:58 PM
its got a seperate unit, he called it a "soft touch"........
look in the parts swap area, hes got photos there
thanks
kevin
Griff 01-17-2005 12:40 AM
Its a TB IV and The limiter looks like a factory Merc one. Should be 5300-5350rpms. You don't have to hook it up at all if you don't want. If it came off a 500HP, then it has a 20* advance module.
Griff 01-17-2005 12:42 AM
Thats a good price if everything is in good shape and its what you need. New, its about $500 worth of stuff.
50boat 01-25-2005 10:08 PM
:D :drink: my frend posted this for me, its perf. built new 540s and wanted 6200 rpm plus.this is how it is i buy high and sell cheep isent this how it works
Griff 01-25-2005 10:51 PM
At least I had an idea of what he was sayin :rolleyes:
boatn70 01-26-2005 09:53 AM
50boat, are you saying this was your ignition set up i bought???
boatn70 01-26-2005 09:56 AM
it seems to be wired in pretty direct, does anyone have a tip on removal of this setup.....doesnt seem to jsut unplug.....ill have to cut and splice if thats the case.
doesnt the part number indicate a 23* advance??? is there anyone to contact to find out exactly what it is?
Griff 01-26-2005 03:02 PM
It should say on the module what the advance is. It should say V8-xx. The xx is the amount of advance. Or post the part #. I have a full list of all TB IV modules and advance amounts at each rpm.
boatn70 01-26-2005 03:48 PM
well, its not a msd soft touch as stated. its wired right to the tb4 unit and just looks like a small rect box with some merc numbers on it
823755A1 and 2425
also the tb4 unit is stamped 5f23a v8-hp
so a 23* advance as you said...id like to know what the limiter is and how to bypass it if needed.
thanks Griff!!
kevin
Griff 01-27-2005 01:38 AM
NO!!! NO!!!! NO!!!!!!
A V8-HP module has 20* of total advance and all advance is in by 3000 rpms.
That rev limiter is factory merc and the same as whats on my 525SC. It will be at 5300-5350rpms. It can be removed. The ignition module and distributor are the same as all TB IV's. The rev limiter is just wired into them.
50boat 02-09-2005 11:58 PM
:rolleyes: i was told this is a merc soft toch rev limitter, & dist. it worked perfect, i wanted to twist my mots to 6200rpm. i hope thier what i sad they are.. :bunny:
boatn70 02-10-2005 07:36 AM
thanks larry! i hope so too, i think i can remove the limiter if needed. i just need to find out how the wiring would be done!
US1 Fountain 02-10-2005 05:44 PM
There is a Merc wiring harness that can be used in place of the rev limiter and it's wires. Can't recall what exactly what it is from. Just that my last boat, which was a '94 with the HP465 motor had the limiter module, and ignition module originaly, but the previous owner removed the limiter and installed a wire harness that was a direct bolt in replacement (no cut and splice thing) from a different ignition set up. Really slick and clean. Maybe this will shed some light and someone else will know exactly what I had.
US1 Fountain 02-10-2005 05:51 PM
Here it is
Item #43 is my factory limiter with wires.
http://www.mercruiserparts.com/Show_...2%2DF213244%29
Item #10 is what I had when the limiter was not used with my blower motor setup http://www.mercruiserparts.com/Show_...+ELBOW%29TB+IV
