cam card
anyone have specs.and timing card of a Ultradyne 284/292 HR12 HR14/HR15 ?
thank you! |
Re: cam card
awesomerott,
Is this a new Ultradyne (Bullet Cams), an older UD when Harold Brookeshire had the company, or the Lunati version of the Ultradyne line? Bob |
Re: cam card
thank you! 292/242@ .050 160@ .200 .600lift. |
Re: cam card
I can't tel you Bob.
the boat is a 1999 and motor Gen v1 the cam is stamp as UD 284/292 HR12 HR14/HR15,also there is a I orT 5266 . the UD is writhen by hand. |
Re: cam card
Originally Posted by rmbuilder
awesomerott,
Re: cam card
awesomerott,
Is this a new Ultradyne (Bullet Cams), an older UD when Harold Brookeshire had the company, or the Lunati version of the Ultradyne line? Bob the back end of the cam have stamped #'s 8 98 L or Z (more likely a L) sorry if i misinformed you! hope this will bring some light. JP. |
Re: cam card
Awesomerott,
Here is the information on that cam; 284*/292* 230*/238* 112* LSA 108* ICL .3533"/.3533" lobe .601"/.601" valve w/1.7 rockers The HR14 is the master lobe number for the intake The HR15 is the master lobe number for the exhaust The I/T 5266 is the serial number Bob |
Re: cam card
thank's much appreciated!Bob
Re: cam card
Awesomerott,
Re: cam card
do you also have the seat timing ?
Re: cam card
Seat timing @ .006" on a 108* ICL
IVO 34* BTDC IVC 70* ABDC EVO 82* BBDC EVC 30* ATDC Bob |
Re: cam card
do you also have the timing at .050?
Re: cam card
.050" timing on a 108* recommended ICL
IVO 7* BTDC IVC 43* ABDC EVO 55* BBDC EVC 3* ATDC Bob |
Re: cam card
thank's Bob much appreciated.
still would like to know if it's a old UD or bullet or lunati version? |
Re: cam card
It's an Ultradyne
Bob |
Re: cam card
thank you kindely!
| All times are GMT -5. The time now is 08:02 PM. |
