-   -   Ford 351 Compression Ratio (https://www.offshoreonly.com/forums/general-q/96082-ford-351-compression-ratio.html)
davids94 02-08-2005 10:05 AM
Does anyone recognize these pistons? Im trying to figure out my compression ratiio for the new motor Im going to be building. Should I stay with these pistons or go with something else? I may use my old 302 heads.
http://plaza.ufl.edu/dspear/ebaypics/351piston.JPG
davids94 02-08-2005 02:45 PM
Re: Ford 351 Compression Ratio
This 351 Windsor was originally a marine motor .... has anyone ever seen pistons like this before?
bglz42 02-08-2005 05:35 PM
I just finished putting the heads back on my 1970 Holman Moody 351W (1970 Donzi 18 2+3) this weekend. Mine had the same pistons. My HM plate reads 9.6 to 1 compression ratio. What head castings do you have? Mine were D00E-C's.
Jim
AA/FuelCoupe 02-09-2005 08:33 AM
David
351W came with '69-'76 .230 dish & 1.739CH
'77-'91 .105 dish & 1.752CH
'93-'97 .180 dish & 1.770CH
Chamber Volume will set final C/R
Richard
RCD Racing Engines
Let me know if you need info or parts for this engine
davids94 02-09-2005 07:51 PM
It turns out theyre standard 351 pistons
