-   -   Mercury Racing Class I Engine (https://www.offshoreonly.com/forums/general-q/96365-mercury-racing-class-i-engine.html)
chromecat 02-11-2005 09:59 PM
1 Attachment(s)
Does anybody have the specs on these engines.. i believe they quit making them in the mid 90's ...
Thanks in advance.
Don
mcollinstn 02-12-2005 01:42 AM
Re: Mercury Racing Class I Engine
can you say "race gas only"?
bubba 02-12-2005 03:05 AM
the make the from 1993 till 1998 serial number from OD763836 and up that is what the part catalog say
chromecat 02-12-2005 08:26 AM
thanks,,, anybody know the minimum octane .?
Don
outriggers 02-12-2005 08:48 AM
I grew up around dirt modified stock cars so that is what I thought all big blocks looked like. I think sometime in the 80's they changed the rules to disallow injectors. They burned alcohol. Very fast. Doug
WETTE VETTE 02-12-2005 09:24 AM
That motor will run fine on 110 octane leaded. I would not try to run less than that. 114 or greater may actaully hurt the performance and your wallet, but the motor will be OK. That motor really shows the performance potential of custom Big Chief heads. Try to get 850 HP out of 500" NA with conventional BBC heads for a marine application and it would be very difficult even at 12+ compression! :D
WETTE VETTE 02-12-2005 10:27 AM
I know they are Crane solid rollers, but I don't know the specs. That type of EFI would look so cool on my 598!! :D I wonder if it is coast guard approved? :cool:
chromecat 02-12-2005 12:01 PM
well.. i'm curious to run it on the water... its in a 2600 NXS AO, with a bravo drive...1.36 i heard it run on the hose in the yard and I was very impressed..
Don
NOBODY 02-12-2005 12:09 PM
I have 2 sets of intake manifolds off those engines. 1 is complete and other three missing miss parts. Saving them for a big inch natty project. Probly use different fuel railes and BIGSTUFF 3,ACELL GEN 7, or F.A.S.T. ecm's.
bob 02-12-2005 10:51 PM
I coverted a pair to pleasure use. Dropped compression down to 9.5, put on a dominator, and made 750 at 6800 at Eickert's. Then found out the stick was just a little too big and solid roller lifter life was around 25-30 hours. So we changed out to a smaller cam and did some other things to get life to 100+ hours. Life was good again. Then decided the injection would be cool, put the injection back on and set up with the FAST system. which is programable. The std Merc ecu is not. There are some components of the electircal system as well that are now NLA. The injection was not real user friendly. Sold the heads and injection and put on some Canfields with blowers and forgot about messing around any more :D The stock Merc Class 1 setup in front of a Bravo may be tough as the motor likes an idle around 1000-1100. The Bravo will not :(
