-   -   Exhaust thru an extension box (https://www.offshoreonly.com/forums/general-q/96408-exhaust-thru-extension-box.html)
BZ 02-12-2005 04:50 PM
I am looking at a new 382 formula and it has stelling boxes and corsa captians call that runs thru the extension bax. I have never heard of this I thought that with box's you had to run mufflers??? Anybody ever heard of this b/4.
Formula Outlaw 02-12-2005 04:52 PM
Re: Exhaust thru an extension box
Nope.
Falcon 02-12-2005 05:00 PM
I don't know about the stellings box, but the ITS can use the standard bullhorn exhaust connection.
BZ 02-12-2005 05:13 PM
per the dealer it's a merc. racing set up??? i will me in miami on wed. for th show and i need to look at this set up
John B 02-12-2005 09:06 PM
I have a 2003 382 with Corsa Captains call with Corsa extensions that go Thu the Stellings boxes. It was installed at the Formula factory and works fine. The motors are Merc 525's.
BZ 02-13-2005 09:27 AM
sounds like the set up but this boat has 575's, do you like the boat set up this way??? and how does it run???
John B 02-14-2005 09:40 PM
It runs well. The Corsa tips cost about 3 mph off the top speed, so they are gone. With 4 people and 100 gallons it runs 79 to 81 at sea level in the Fla Keys. The best I have seen is 84.6 in fresh water at 800 ft. Haven't done any light testing in the salt water but I would guess 85 + is possible. You will need 5 blade props to allow low speed capability, (staying on plane). The corsa opens up at 2800 - 3000 rpm no matter what, and this can be annoying.
Cord 02-15-2005 11:44 AM
I have an Stellings extension box. The space in there is very tight. BUT! If a extension was fabricated I could see the exhaust being put through there. Sure would be tight though.
JaayTeee 02-15-2005 12:54 PM
A friend of mine has exhaust going
through stellings boxes.
It has a piece of exhaust hose, connected
to a couple of adapters( to connect to the
y pipe, and transom assy) on each end.
And yes, it's a tight fit.
jt
BZ 02-15-2005 11:19 PM
i run mainly in lake mich. and i agree, the "muffler tips" have to go i like the old school look of the angle cut tips from cp. sounds like a lot of work to me?????
