-   -   Forged or hypereutectic pistons? (https://www.offshoreonly.com/forums/general-q/96479-forged-hypereutectic-pistons.html)
phughes69 02-13-2005 10:00 PM
I pulled my motor apart tonight and found the top ring land gone on one piston. Now I have to figure out what kind of pistons to run. The motor will be a 468 with cast iron rectangular heads and twin turbos running about 10 psi of boost. Should I consider running a hypereutectic piston at this boost level. The inital compression with the hypereutectic pistons will be about 7.5
Biggus 02-13-2005 10:09 PM
Re: Forged or hypereutectic pistons?
I'd run nothing but forged pistons.
Isn't 'Hypereautectic' just a fancy word for a cast piston with a high silicon content? :D
I like to build them with the best parts so you can feel good about it when you have the throttles mashed to the dash :D
:evilb: more .02 :D
Kurt
NOBODY 02-13-2005 10:21 PM
Forged all the way. All Hyper. pistons are good for is dissipating heat faster, but at a cost of strength. Forged pistons are denser therefore hold heat longer, but take more abuse.
BGIII 02-13-2005 11:08 PM
I broke one of those pieces of crap on an under 100 hour 454 rebuild. I will never have that problem again! Forged only.
mcollinstn 02-14-2005 07:34 AM
you want forged turbo pistons with extra thick top lands.
dykstra 02-14-2005 08:03 AM
Forged :D
mikes280 02-14-2005 08:35 AM
forged is the only safe way to go and i would get a peice made for usng a turbo spend the money now and you won't regret it :D
