Re: Dyno #'s HP 500
1 Attachment(s)
#'s - I'll get the details from my engine builder for cam specs. He is very well known for his head port work.
Re: Dyno #'s HP 500
Final #'s 5400rpm 608.6 tq 625.8 hp :D
Re: Dyno #'s HP 500
Doc,
Did you keep the stock throttle body or did you install a larger one like the one's that are on the 525's.? Also what about the reprogramming of the ECU. I'm changing my heads and adding the A/S throttle body to my 500EFI's. I should say I'm adding the entrie 500 EFI upgrade kit from A/S. If I make 550 HP and pick-up some additional Torque from my bolt on I will be happy. |
Re: Dyno #'s HP 500
Originally Posted by Dock Holiday
If you just kept everything stock and simply freshened them up I say it sounds very good.
I just dynoed one of my 500 EFI's last week. We changed the heads to World Merlin II's, Rect Port 320 CC. Bumped the compression fro 8.75:1 up to 9.1:1 and kept everything else stock. Of course freshened up the entire motor. These are the dyno numbers. 4300 RPM HP= 526.9 Torque = 643.6 Ft Lbs (Max Torque) 5200 RPM HP= 598.0 Torque = 604.0 Ft Lbs (Max HP) The rev limiter kicked in and it was still making horsepower. Hope this helps for a comparsion. Doc |
Re: Dyno #'s HP 500
Originally Posted by IndianaHeat
Doc any ECU work? nice numbers Ran Dom 32
Re: Dyno #'s HP 500
VERY NICE NUMBERS! Congrats |
Re: Dyno #'s HP 500
Originally Posted by sutphen30
are you using the stock hp500 efi cam?if not which one,thanks
Yes, both stock cam and stock throttle body. |
Re: Dyno #'s HP 500
I am curious, what does a 500efi pull on a Dyno brand new?? Is it just 500hp?? I think you gains are awsome but damn 100+ hp for just working the stock heads? You make me want to pull my 500efi and do it :D
WILL |
Re: Dyno #'s HP 500
Supposed to be between 500 and 517 HP will, out of the box.
Re: Dyno #'s HP 500
I am putting 525EFI Cams, cometic .027 gaskets and Iron Eagle 308 heads on mine. 9.38CR, 120 Thermostat, Big flow numbers on the heads, See Nordic Section
| All times are GMT -5. The time now is 03:38 PM. |
