Blown 509 head recommendations
I want to upgrade the heads on my engine.
Currently running stock rec ports with inconel exh valves. Setup now is 509ci,8.75 compression,hyd. flat tappet cam, B&M 250 blower(6lbs boost),Nickerson preped dominator,gil exhaust. Considering:Dart iron eagle,Merlin(iron) and Edelbrock aluminum. What do you guys think? Of course I'm looking for the most bang for the buck.The eldebrocks seem like a good deal,anyone have any experience running them with a little blower? Any one have flow spec for the iron eagles or merlins?(310-320 runners) Thanks,Jeff |
Re: Blown 509 head recommendations
:D :rolleyes: if your using a 502 block with angler shape water pasages at the head and , youal probabuly keep blowing gaskets.. if you have round water passages,,i think your ok.... blocks with anguler passages dont like blowers. :bunny: :bunny: :bunny:
I used Brodix BB2 Plus in a similiar setup dynoed 805hp and ran great.
Thanks for the replys.
50boat, I'm using cometic gaskets and am not having sealing issues.I'm looking for new head recommendations. I boat in salt water so if I go aluminum they will need to be hard anodized. Who sells canfields or brodix hard anodized with inconel valves in them already and what do they cost? I dont want to spend $2500 on a set of heads. I was looking at the Edelbrocks because for about $1400 you get the inconel valves and anodizing,I know I'm gonna have to add springs,retainers, etc. to them. I'm still looking for flow #'s to plug into desktop dyno. My goal here is somewhere in the 600-650 hp range,gotta keep it somewhat tame for the family Thanks |
Brodix will upgrade you to Manley Inconel and they should run about $2200 fully assembled ready to bolt on. The website has all the flow numbers listed at Brodix.com
Good Luck! |
The Iron Eagles are a great deal and flow very well. I would pick them for salt water. Jim V can make them flow 400/300 at .6 lift.
profile you should be close to your goal with what you have.
| All times are GMT -5. The time now is 05:41 PM. |
