-   -   water pressure (https://www.offshoreonly.com/forums/general-q/97078-water-pressure.html)
mv35 02-23-2005 02:20 PM
water pressure
can anyone tell me if there is a better location to draw water pressure from rather than the bottom side ofthe block.and the best place to install a pop off valve.thanks.
737jetmech 02-23-2005 02:35 PM
Re: water pressure
My pressure is taken from the intake manifolds...the pop-off valves are installed just prior to entering the cross-overs and dump out the side of the boat. Pressure is around 28 psi @ full throttle which is the pressure valves by-pass. The lower block location tend to become clogged over time (fresh water cooled)
Bob
Python82 02-23-2005 02:45 PM
Re: water pressure
What kind of pop off valves are most people using??? and do you install it before the water goes into the crossover???
737jetmech 02-23-2005 03:20 PM
Re: water pressure
Mercury racing sells them for around $102. (cheap plastic)
installed before the crossover ... and after the oil cooler ...
Bob
Python82 02-23-2005 03:42 PM
Re: water pressure
Does anyone else make one??? If not where could I buy the Mercury racing one? Part Number???
Thanks again
737jetmech 02-23-2005 04:09 PM
Re: water pressure
part # 863208A 3 (Mercury Racing)
www.mercruiserparts.com (Bam marine) is where I purchased them.
mv35 02-24-2005 06:53 AM
Re: water pressure
bob thanks for the info.where did you tap your water pressure line from the intakes.i have supercharged engines w\no thermostats.
737jetmech 02-24-2005 03:33 PM
Re: water pressure
3 Attachment(s)
I used a spare temp sender boss on the front of manifolds.Here are a few pics of the installation
Bob
737jetmech 02-25-2005 09:04 PM
Re: water pressure
1 Attachment(s)
each dump is located just outboard of engines ... sorry its not the best picture ...
