Closed Cooling Question
When using a closed cooling system like Innovation Marine uses on many of their engines, are the water jackets in the exhaust system part of the closed cooling system or does the raw sea water run through it? Does the raw sea water simply run through the raw water pump through the heat exchanger and then dump overboard?
Thanks |
Re: Closed Cooling Question
Thanks |
I owned the Innovation DPX 600's. I agree with the above statements, and would like to add that you should treat the headers carefully by flushing and draining to prevent water in the cylinders. I caught mine just in time.... I think next time out the motors would have hydraulicked. The headers were four years old and occasionally I did not flush them. :eek:
2 Attachment(s)
There are closed cooling systems available that circulate through the exhaust manifolds. The raw water is discharged through the tailpipe or riser. The system you described would be a "Partial Closed Cooling System".
Here's a couple diagrams of these types of systems to give you an idea of how these work. If you need a quote on a system just give us a call. |
gotta just about double the size of the heat exchanger if you close in the exhausts...
I've got MarinePower EFI Big Blocks and they are standard with the full closed colling system. THe raw water (sea water) from the heat exchanger is dumped to the exhaust at the riser (elbow). THere is a stainless steel gasket that seals off the manifold/coolant from the riser/elbo area.
In my situation we had to use 6" spacer blocks and we set system up so the spacers are also cooled by coolant from the heat exchanger instead of raw water. |
I installed a FULL system on my engine and the engine temp. dropped 10 to 15 deg. and the heat exchanger is normal size you just need a system designed to handle it all.
Suggestion: add header drains so you do not have to flush headers. All salt water will drain from the bottom of the headers when the engine is turned off.
Skaterboy,
Got any pics of a setup like that? Where do they drain and how is it automatic? |
Viper 31,
Sorry "no pictures" at this time the boat is all covered, but if you are familiar with the 525EFI engine there is a common rail just below the header that runs the whole length. By simply removing the plug from the lowest end of the common rail and connecting a hose to it. Then install a exit stainless steel fitting on the side of the boat (above water level but below the headers) and connect the hose. The excess flow of water will flow while the engine is running and then when you shut the engine down , all the water left in the headers will automatically just drain out. |
If you've seen a full cutaway of either a tubular header like CMI or a cast manifold like Gil's you would notice that the actual water passages in some areas are very small so it would not take much of a build up to cause a blockage. If a blockage were to develop you would then have hot spots in the header which would lead to premature failure. If you're going to drain the headers after each use which is highly recommended, you should first flush the system completely and preferably with the use of a product such as Salt-Away to neutralize and remove the potential of salt crystals forming within the system. Hope this helps, if you have any more questions just ask! |
When you have an over heat issue in these systems what are the usual culprits to check out?
| All times are GMT -5. The time now is 07:21 PM. |
