-   -   Fuse Problem? (https://www.offshoreonly.com/forums/general-q/97743-fuse-problem.html)
zog02 03-06-2005 07:47 PM
Fuse Problem?
I have an 89 223LS. I recently pulled her out of storage for the winter and noticed that the bilge pump and blowers are not working. The depth sounder and all the lights are working properly. The stereo also works fine. I noticed that the fuses for everything but the blowers, bilge and stereo memory are under the drivers console. The fuses for the blowers and bilge pump are under the bench seat. They are the old type fuses. (The round ones that you push in) I don't know how to remove them to check them. Do you just pull them out?
My question is basically why are my bilge pump and blowers not working? I imagine its something do with the fuses because they are the only two together. Any help would be GREATLY appreciated. Thanks!!!
Vinny P 03-06-2005 08:27 PM
Re: Fuse Problem?
The right way to check a fuse is with a test light. Ground the clip and check for power on both sides of the fuse. You will have to turn the ignition on to check all the fuses.
