-   -   Tool to cut Stainless Dash panels (https://www.offshoreonly.com/forums/general-q/98009-tool-cut-stainless-dash-panels.html)
MILD THUNDER 03-10-2005 02:02 PM
I have a nice sheet of brushed stainless steel off a new dishwasher. It is about 1/8" thick. I would like to take my old plastic dash panels and use them for templates. Question is, what can I cut the holes with for the gauges?
Chris288 03-10-2005 02:05 PM
Re: Tool to cut Stainless Dash panels
certain types of Stainless are very tough,,, although a hole saw might work, for the best results you should probably have a machine shop put them on a milling machine and bore out the holes
cougarman 03-10-2005 02:37 PM
We use all carbide tooling, hole saw may work if you use plenty of oil to keep it lubricated.
Cougarman
US1 Fountain 03-10-2005 03:22 PM
main thing to remember is to turn SLOWLY. Slow enough you can count the revs.
dukenrock 03-10-2005 03:56 PM
A guy I work with has a brother in law who purchased a water jet (a water fed torch) He cut out a harley davidson logo on a 1/2" copper for me. It runs off a computer program that he made. I think he just copied the picture as a jpeg and made changes from there. Should work great for this application.
Chris Sunkin 03-10-2005 04:32 PM
Milwaukee hole saws in a drill press using cutting oil. You can use clay from Wal Mart's flower section to make a dam to keep the oil in the cut.
120 feet per minute is the cutting speed you need to hit. Stainless is softer than mild steel and it is very susceptible to galling at incorrect cutting speeds. If you're doing 2 5/8" gauges, the cutting speed is going to be 175 RPM. Take diameter x pi and divide cutting speed (1440 ipm) by that number for RPM. Use the same figure for sawing.
Too slow and the cutter will fill up with chips galled to the teeth, too fast and you'll smoke the blade.
Cord 03-10-2005 06:09 PM
Um, what was that dishwasher? An industrial unit? If not, then the ss must be thinner than 1/8. Anyways, I've used hole saws successfully in the past. Turn them very slow and flood the surface with oil. Try to pump the oil into the teeth.
formula31 03-10-2005 06:59 PM
Doesnt your wife get mad when you strip her appliances for boat parts? :drink:
mcollinstn 03-10-2005 07:13 PM
Be sure to lay it on a piece of wood and cut thru into the wood. This will reduce the bellmouthing and keep it from grabbing when it breaks thru.
Waterjet is definitely a cool unit, but you should expect to pay about a buck for each 2 inches of linear cut. Most places have a $75 minimum on their waterjet for retail customers.
pachangalpina 03-10-2005 07:41 PM
I can laser etch stainless if you need to add any text or logo's to your finished panels. :eureka: ;)
puder 03-10-2005 11:22 PM
water jet or
laser cutter or
CNC router table or
mill
if you want to do it right.
phebus 03-11-2005 11:10 AM
The bezels cover a pretty good size area over the hole, so if they are slightly burred or rough, it shouldn't matter much. I would use a carbide hole saw with your stainless stock supported on a piece of wood.
The hole doesn't have to be perfect, it won't be seen.
Chris288 03-11-2005 11:29 AM
what ever you do,, don't work harden the metal,, if you do, you will be S.O.L unless you have a carbide cutter.. keep the revs low and keep the tool cutting..
formula31 03-11-2005 11:43 AM
Very true, I think what Chris means in laymans terms is, apply enough force to cut, dont let the teeth drag and slide on the surface. Right Chris?
Chris288 03-11-2005 11:47 AM
yah,, Stainless is very easily work hardened,, once that happens it's near impossible to drill or cut without carbide or diamond,, and even then you will most likely ruin the tool cutting it..
Personally I hate machining SS.. I would rather make the panels out of aluminum and have them engraved and hard anodized a cool color to match the boat..
Lofty 03-11-2005 11:50 AM
Mild Thunder,
STOP!!!
Kitchen appliences use 316 stainless. It's gummy when you cut it and you'll probably f' it up using garage methods. Laser, waterjet, EDM work well, depending on the thikness of stock. You can use carbide cutters but you'll need to hold the part well with a backer. You'll also need to chuck your cutter well so you don't get chatter.
Good luck!
Fionn
Puder pic up your phone mo' fo'!!!
puder 03-11-2005 02:54 PM
holy lord he lives!!!!!! leave a VM if ya call!!!!!!!!!
i'll give ya a buzz later on tonight.
Chris288 03-11-2005 03:05 PM
GO ALUMINUM and have it anodized.. :cool:
Lofty 03-11-2005 09:19 PM
1 Attachment(s)
I'm with Cris on the aluminum thing. Best thing is 1/8 alum plate, cnc router cut it, powder coat then lazer etch lettering. Sweeeet!
Lofty 03-11-2005 09:21 PM
Puder yo're funny man!!! Yep, been down.... I feel like a one-legged man in an azz kicking contest. Call or I'll call you bro'. Thank the lord it's sunny and warm here and I think summer is in.
